Component upgrade query
Grgic
Postby Grgic » Fri Apr 11, 2014 3:51 am
Hi.
Recently bought a 2nd hand bike and have noted that the teeth on the chain rings and the chain itself are quite worn and require replacing.
So I'm looking at replacing the cassette, chainset and chain all in one foul swoop.
Is anyone able to tell me if the Shimano Ultegra 6750 Hollowtech II Compact Chainset will work on a Shimano BB – 4500 bottom bracket?
(Sorry my mechanical knowledge is limited after many a year out of the sport)
Thanks!
MattyK
Re: Component upgrade query
Postby MattyK » Fri Apr 11, 2014 7:24 am
Is it actually worn or is that just the tooth profiling of a modern chainring?
Grgic
Postby Grgic » Fri Apr 11, 2014 8:52 am
It's actually worn. Been commented on by a couple of people.
Postby RonK » Fri Apr 11, 2014 9:01 am
Grgic wrote:It's actually worn. Been commented on by a couple of people.
A lot of people haven't a clue - as has been established here.
barefoot
Postby barefoot » Fri Apr 11, 2014 9:20 am
Grgic wrote:Is anyone able to tell me if the Shimano Ultegra 6750 Hollowtech II Compact Chainset will work on a Shimano BB – 4500 bottom bracket?
Yes.
There are only two types of HollowtechII external bearing BBs: road and MTB.
The MTB ones are 1mm narrower on each bearing race, longer in the thread, and are supposed to be used with spacers behind them. Road ones... the opposite to that.
BB-4500 is nominally a Tiagra BB, so it will be the wide-bearing-no-spacers road style. May or may not be any different in construction to higher specced road group BBs... may or may not be just a different colour for a different price ;-).
Either way, a Tiagra HT2 BB will certainly fit an Ultegra HT2 crankset.
I'll leave it to others to decide on your behalf whether or not you really want an Ultegra HT2, because strangers on the internet know best :lol:
tim
Postby Duck! » Fri Apr 11, 2014 9:20 am
Perfectly fine.
Postby Duck! » Fri Apr 11, 2014 9:24 am
barefoot wrote:The MTB ones are 1mm narrower on each bearing race, longer in the thread, and are supposed to be used with spacers behind them.
The spacers are only to allow compatibility with various bottom bracket shell widths, and BB-mounted chain guides or front derailleurs or not. It's a case of design for the widest assembly necessary, and then add spacers as other bits get removed.
barefoot
Postby barefoot » Fri Apr 11, 2014 10:00 am
True - but the total installed width of a MTB BB + spacers + frame is wider than the installed width of a road BB + frame. The spindle of a MTB crankset is longer to suit.
Main point being, though - all road group BBs are the same; all MTB group BBs are different to that, and not readily [1] interchangeable with the road ones.
tim
[1] I have a MTB BB and road crankset and a spacer on my road bike. Oops.
Postby Duck! » Fri Apr 11, 2014 11:38 am
I think you missed my point a bit Tim.... MTB bottom bracket shells are commonly 73mm wide, compared to 68 (and increadingly rarely 70) mm. Then factor in the use of a BB-mounted chain device & you have an assembly that takes quite a bit of real estate that needs to be designed for. The spacers are to compensate for the absence of chain device, narrower BB shell or a combination of both.
Dragster1
Postby Dragster1 » Fri Apr 11, 2014 12:30 pm
Im sure you can run a mtb bb in a road bike set up not that you would really want to, most likely not too safe running a roadie bb in a mtb because the thread lengh is shorter unless you have a 68 mm bb frame with no brackets attached to the drive side
Postby RonK » Fri Apr 11, 2014 1:07 pm
Dragster1 wrote:Im sure you can run a mtb bb in a road bike set up not that you would really want to...
Why not - it's common practice to use MTB cranksets with touring road bikes.
Dragster1
Postby Dragster1 » Fri Apr 11, 2014 1:58 pm
They use them on cyclocross too, The road bbs are smoother, The road bike frame bb may not except the longer thread of the drive side bearing housing and the chain line measurement can be different also depending of what bike you have.
mitchy_
Postby mitchy_ » Fri Apr 11, 2014 2:32 pm
i have a MTB BB in my disc CX with a Sram Red crank... does the job.
Designs by Mitch - drafting specialist.
barefoot
Postby barefoot » Fri Apr 11, 2014 3:37 pm
Yes, yes, yes... reasons, exceptions, explanations, possibilities.
All road HT2 BBs are interchangeable. MTB HT2 BBs are different. That answers the question.
Grgic
Postby Grgic » Fri Apr 11, 2014 8:49 pm
Thanks for the feedback all. I'll go ahead with my purchase then.
Users browsing this forum: uart, Yahoo [Bot]
