janus77 wrote:ok, using spacers I understand, however if a hub is 120mm, wouldn't the axle be too short? I mean there wouldn't be that much extra axle to space it out would there?
Guess I should check the manufacturer specs of hubs for axle length to see how far it will accommodate spacing.
Axle length is critical. To space out to 126mm, you need extra axle space of 3mm each side, to space out to 130mm you need extra axle space of 5mm a side.
I've just run a quick ruler over the axle length of some of my 120mm spaced track/fixed hubs.
Sanshin Pro 160mm
Sanshin Pro NJS 155mm
Velocity/Formula 156mm
Bianchi/Formula 156mm
Campag Record 149mm and 152mm.
I also measured some steel road and track dropout widths mostly 4 to 5mm each side, although cheap pressed steel was 3mm, and alloy can be thicker at 6mm +.
Also found that most decent track nuts are 12 to 13mm wide.
So, say for a steel frame with a 130mm spacing and 5mm wide dropouts:
130mm spacing
10mm dropouts
25mm nuts
165mm total.
Or a steel frame with 126mm spacing and 4mm dropouts:
126mm spacing
8mm droupouts
25mm nuts
159mm total.
However having said that I'd take my 160mm Sanshin axle out to a 130mm spacing if necessary on 4mm dropouts for road use, I would not be overly concerned with a calculated 1.5mm axle deficit per side, that's only a thread per side in the track nuts and I'm not Theo Bos
