Tyre direction (does it matter?)
matthecat
Postby matthecat » Thu Jul 17, 2014 11:49 am
Hi all,
Have recently changed tyres (Maxxis Detonator?) on my commuting bike and noticed they had a directional arrow on them, which I've never noticed before on any tyres I've used.
A couple of questions:
1) Does it matter if they are on the wrong way?
2) What is the technique to ensure you get it right
Regards
mitchy_
Re: Tyre direction (does it matter?)
Postby mitchy_ » Thu Jul 17, 2014 11:52 am
matthecat wrote:Hi all,
Regards
1) not entirely, if they have a tread pattern it's mainly for water dispersion on a road bike. mtb is a whole other kettle of fish.
2) put it on the right way
:shock:
Designs by Mitch - drafting specialist.
harmonix1234
Postby harmonix1234 » Thu Jul 17, 2014 11:58 am
I still do this after 25 years of changing tyres. I always have my bike upside down when I change tyres, so all I do is make sure that the arrow is at the bottom of the wheel as if you are holding the wheel out in front of you, and face it pointing towards the front of the bike. Also, directional tread is sometimes more important for water shedding than it is for traction. But every tyre is different. Just flip it round.
silentC
Postby silentC » Thu Jul 17, 2014 12:17 pm
On my roadie, the tyres don't typically have a direction, or any tread to speak of. On the MTB, if the tread is directional I fit them so that he front one has the 'arrows' pointing towards the front of the bike when viewed from the top. I fit the rear one the opposite. The theory is that the tread direction assists braking/steering on the front and drive traction at the rear. I've never tested that out but it seems intuitive for a chevron style tread. For tyres that don't have an obvious direction, I guess it doesn't matter.
"If your next bike does not have disc brakes, the bike after that certainly will"
- Me
m@
Postby m@ » Thu Jul 17, 2014 12:17 pm
The correct direction for Detonators is straight into the bin... ;)
ALL THE ABOVEIS TRUE
jacks1071
Postby jacks1071 » Thu Jul 17, 2014 3:21 pm
m@ wrote:The correct direction for Detonators is straight into the bin... ;)
Detonated?
march83
Postby march83 » Thu Jul 17, 2014 4:07 pm
if it has chevrons, they should point forwards when viewed while sitting on the bike - this is to push water outwards and away from the centre of the tread as it rotates.
if they have a label on 1 side only, the label should be on the drive side.
li2099
Postby li2099 » Fri Jul 18, 2014 11:04 am
If it's directional, pointing it in the right direction will give you speed.
Switch it the other way and you'll get more traction!
Postby Duck! » Fri Jul 18, 2014 8:00 pm
On road tyres the tread is so fine it provides little beyond cosmetic effect, but it looks better if it's pointing the right way! Think of the tread forming an arrowhead pattern, and point it the same way the wheel rotates.
On dirt tread direction can have a big effect on the handling of the bike, 'cos the knobs are designed to work a certain way.
Postby RonK » Sat Jul 19, 2014 9:35 am
Ah! Along with the other Refuse then...;) :) :) :)
m@
Postby m@ » Tue Jul 22, 2014 4:40 pm
jacks1071 wrote:Detonated?
RonK wrote:Ah! Along with the other Refuse then...;) :) :) :)
On both counts - exactly so!
Users browsing this forum: queequeg, Thoglette
