Alternative Ay-Up Lighting Mounts?
Postby Dr_Mutley » Tue Aug 12, 2014 2:22 pm
Re: Alternative Ay-Up Lighting Mounts?
Postby Espresso_ » Tue Aug 12, 2014 7:57 pm
Yeah, could do. That's another good suggestion - thanks.Dr_Mutley wrote:Why not just fix the lightset to the bag?
E
Postby madmarsupial » Wed Jun 24, 2015 10:57 am
Part replaces the screw on GoPro mount. Works like the AyUp helmet mount with the C-clamp action (no rubber strap).
Haven't tested it on road yet - need to be sure the clamping action is tight enough.
Sorry - I can't get the img tag to work so you'll have to follow the links to see the photos.
https://picasaweb.google.com/1024634800 ... 3266919650" onclick="window.open(this.href);return false;
https://picasaweb.google.com/1024634800 ... 0047379010" onclick="window.open(this.href);return false;
https://picasaweb.google.com/1024634800 ... 2540205938" onclick="window.open(this.href);return false;
https://picasaweb.google.com/1024634800 ... 7411556674" onclick="window.open(this.href);return false;
Postby Gunlock » Wed Jun 24, 2015 10:59 am
I like!madmarsupial wrote:I'm just working on a mount that will let you use a K-Edge Garmin/GoPro mount.
My better half has a set of Ay-Ups and the only thing stopping me from grabbing a set is the mount. If something like this because available i'd be all over them and it.
- Gassy
Postby Gassy » Wed Jun 24, 2015 11:35 am
- jillybean
Postby jillybean » Wed Jun 24, 2015 12:43 pm
- queequeg
Postby queequeg » Wed Jun 24, 2015 12:48 pm
Will see if I can get details as I am trying to get an elegant solution for Garmin+AyUp on my Cervelo A5 Aero bars
- silentbutdeadly
Postby silentbutdeadly » Wed Jun 24, 2015 1:35 pm
Very clever...
Postby madmarsupial » Wed Jun 24, 2015 6:04 pm
queequeg wrote:I was chatting with RaceWareDirect and they have an AyUp mount that slots into a GoPro mount, so you use an out front Garmin/GoPro mount to mount your AyUps.
I couldn't see it on their website, but a search found a twitter note from them.
https://instagram.com/p/pJYYZBmr5g/" onclick="window.open(this.href);return false;
Looks to be an AyUp to GoPro adaptor - something I was going to do next (once I can work out how to get the dissolving PVA support structures to print properly on my 3d printer!).
Ideally I'd like to make 3 designs:
- the one above, K-Edge mount
- one that uses a GoPro mount
- one that has a Garmin 1/4 turn base on it
Postby milkman » Wed Jun 24, 2015 6:17 pm
Postby madmarsupial » Thu Jun 25, 2015 1:45 am
When I bounced the bike on to the front wheel (lifted wheel about 20cm and dropped) the lights popped out of the clip.
I made a couple of new prototypes, but the first was a bit tight and it broke off the little arms when I clipped the light in. Hopefully the second one is OK. Test riding it tomorrow if it doesn't rain.
The finished product will hopefully be in a stronger and more flexible material, so I can tighten up the clip some more.
Postby madmarsupial » Fri Jun 26, 2015 4:37 pm
It fell out on a quite heavy bump (descending at 50+kph) and whilst I could tighten the C shape a bit, another issue is that the light can rotate. The clip isn't tight enough and there is nothing to stop rotation - the AyUp helmet mounts grip around the power cable socket as well.
So...back to the drawing board.
Much simpler plan working from the RaceWareDirect idea someone mentioned above.
I made a couple of versions before I got to this smaller one. I even did a 'double adaptor' style just in case you really want to mount two sets of lights or put your GoPro on as well.
Actually grips light well. Having the cable socket go through the hole in the body means no rotation and a bit more safety if the light does come unclipped (hopefully the cable holds it).
I'm going to see if I can get a stronger version made, but I'll ride with this for now.
Postby madmarsupial » Fri Jun 26, 2015 4:38 pm
If you click on the links you can see them.
They are also in the original gallery (link above).
- Thoglette
It's late, I'm tired and it's not even September
Postby Thoglette » Sat Jun 27, 2015 1:56 am
Umm, use the IMG tag around images (thing ending in .jpg, .gif or .png) rather than around web pages?madmarsupial wrote:I'd also appreciate if someone could give me the trick to making the photos display!
Even if you are going to "drink the google-aid" it can be done like this
and this
Right mouse on the actual image in your cloud thingy and copy the "image address". Or "open the image" and then copy that address.
- Drizt
Postby Drizt » Sat Jun 27, 2015 8:22 am
Postby madmarsupial » Sat Jun 27, 2015 9:56 am
https://picasaweb.google.com/1024634800 ... MountIdeas" onclick="window.open(this.href);return false;Drizt wrote:Loving your work. Can't see the images on your latest effort though
- Drizt
Postby Drizt » Sat Jun 27, 2015 9:58 am
- Thoglette
Re: It's late, I'm tired and it's not even September
Postby Thoglette » Sat Jun 27, 2015 2:07 pm
Blahh, google is generating one-time-only links. B gger. Worked all right last night, cleared the session and it's a fail for me.Thoglette wrote:Even if you are going to "drink the google-aid" it can be done like this
See if this lasts any longer
Postby eeksll » Sat Jun 27, 2015 3:20 pm
You don't have to have a hole for the power port, it can be stuck straight out of the gap you push the light into. so in your case the power port would be pointing straight down to the ground.
Postby madmarsupial » Mon Jun 29, 2015 12:18 pm
I have uploaded a few designs to a 3d printing service called 'Shapeways'. If you haven't heard of it, they basically act as a printing service for you and offer a lot of options done on much bigger machines. Pretty amazing stuff really!
The designs are listed as 'beta' (still in testing) but I think I've clicked all the right buttons to allow anyone to purchase one.
https://www.shapeways.com/designer/Womb ... t_Workshop" onclick="window.open(this.href);return false;
I think the postage cost will be more expensive than the actual parts, but if it solves your problem it should be worth it. If the design proves to work well then it might be worthwhile arranging a bulk order to get costs down.
If anyone does buy one I'd love to get some feedback so I can make improvements.
- apsilon
Postby apsilon » Mon Jun 29, 2015 12:41 pm
Postby madmarsupial » Mon Jun 29, 2015 1:00 pm
Let me know if you do!apsilon wrote:Nice work. If I order anything from Shapreways in the near future I'll grab these as well (of course I'd then need to order a KEdge mount but being able to mount camera and lights on one mount would be nice.
Having a light and a camera at the same time would be good. It can be a pain if you have to ditch one for the other or rearrange everything on the handlebars to fit in something extra (presuming you don't want to go helmet mount).
I'll put up some pictures of the 2-in-1 GoPro mount with lights and camera attached when it arrives.
Postby madmarsupial » Mon Jun 29, 2015 1:02 pm
I found that the light could rotate a bit if the power port wasn't locked in somehow. Not sure I could make the clipping action tight enough to stop any rotation without making it prone to breakage.eeksll wrote:I am doing something similar with a bit of round pvc pipe glued to an existing mount. No where near as pretty.
Postby eeksll » Mon Jun 29, 2015 1:25 pm
so my solution to this is to glue some rubber on the inside. I got my idea from a exposure light bracket which I used in a pinch to mount the ayups because I couldnt find any zipties.madmarsupial wrote:I found that the light could rotate a bit if the power port wasn't locked in somehow. Not sure I could make the clipping action tight enough to stop any rotation without making it prone to breakage.eeksll wrote:I am doing something similar with a bit of round pvc pipe glued to an existing mount. No where near as pretty.
That mount will put the ayup lights vertical (worked in a pinch not ideal for a few reasons). But the light brackets was actuallly too big for the 16mm ayup cross-beam, so I was forced to use some rubber.
incidently the bit of pipe I purchsed for my ghetto solution was in fact 16mm diameter on the inside exactly, at the time I was like "woo hoo what are the chances?" would have been nice for it to be just a tad bigger now. But you could easily design yours to have a bit bigger internal diameter.
note: I am not trying to create a mount for the garmin mount, I just wanted a quicker quick-relase for the lights cause the ayup handlebar mount solution with the rubber is annoyingly fiddly.
I also want to drill a hole in the bottom but i figured there wasn't going to be enough plastic after that.
- queequeg
Postby queequeg » Mon Jun 29, 2015 1:48 pm
On my S5 it is a dirty hack due to the aero bars.
