lube lube lube
limetang
Re: Type of Chain Lubricants (Polls)
Postby limetang » Mon Apr 12, 2010 4:52 pm
stevepedlin wrote:I've been using tri-flow, a wet ptfe based lube. not on the list.
Same here
Oh Wheely
Postby Oh Wheely » Sun Apr 29, 2012 10:33 pm
I have used almost EVERY formulation of lubricants and even the ones I have designed myself.......
Mainly because I now live in an agricultural area, that has main highways between the towns and dirt roads everywhere else, and dust and crap from all the ploughing and top soil blowing away, just covers the sealed roads with GRIT and DUST.
Since it's a REAL issue to shield the chain or enclose the drive system etc... I have more or less given up the idea of anything less than either a more or less totally enclosed drive or moving to hydraulics, or to use dry lubes - that are self cleaning, in copoius amounts.
My bike is my sole mode of transport so it gets treated like a work vehicle, I am not going to pull the chain off every week and clean it and dry it and oil it and wipe it..... only to repeat the process.
Your damned right I sulk and cry and throw temper tantrums - because I'd really like to keep all the crap off the chain and gears in the first place.
So I have just given up cleaning with scrubbing brushes, solvents, compressed air and more scrubbing and brushing and solvents and relubing and wiping and another 4 or 5 days later the chain and gears are covered in black grinding paste again and then the endless weekly clean and lube and doing that month in, month out, year in and year out......
I can make my chains shiny and clean and internally free of all grit and crap - but a week later, it's all back to square one..... full of free grinding compound.
I have also found that the total loss "constant drip feed" oiling systems that are great on motorbikes are not so good on bicycles, nor are copoius regular drenchings of the chain - to keep the crud flushing off the chain.....
Vegetable oils are great - but they tend to dry into a varnish when the excess lands everywhere else and never gets wiped up.
All the wet lubes attract dirt, all the dry ones - well Tri Flow Sucked, the Lightning lubes are fine - but too expensive in their TINY little premium priced bottles, and I am thinking that the Squirt lubricant may be the way to go.
Apply weekly and it's self cleaning as I go.
That is about all a MODERN chain lube should be.
I'd still rather that the chain drives be fully enclosed and running in an oil bath, or that a directly driven gear box and shaft drive be fitted into the frame.
Hydraulics ARE good, but at this stage - the power losses are too high to accomodate with the mere mortal power source.
I also hate buying the teeny little bottles of "speciality lubes", I'd rather just get one or two, one liter bottles of it, and come back for seconds after 20 years.
If I could give the chain a good weekly weed and feed with a decent douse of the self cleaning lube and be done with it, I'd be happy with that.
The White Lightning "CLEAN" is sold here in 1 liter bottles.... I think I feel a purchase coming on - unless the Squirt people can make me a similar offer, I will get this. it builds up crud around the jockey wheels but applying 5ml or 10ml every week, a quick wipe and doing nothing else, has much appeal.
http://www.bumsonbikes.com.au/bikes/bik ... -758.html#
Time to go cry and hit the pillows, "Ohh my chain gets dirty and I have to clean it again".... Boo Hooooo.
Postby il padrone » Sun Apr 29, 2012 10:48 pm
I am led to believe this is a very effective solution to the problem.
Oh Wheely
Postby Oh Wheely » Sun Apr 29, 2012 11:19 pm
il padrone wrote:I am led to believe this is a very effective solution to the problem.
Ummmmm my bike already has a side stand.
No serious - what is the brand name and model of the internally geared hub?
The fixed ratio chain with the guards looks good and almost totally screening of the dust.
Postby il padrone » Sun Apr 29, 2012 11:33 pm
The hub is the Rohloff Speedhub 500/14.... probably the CC DB OEM model (quick release, disc brake, OEM Rohloff drop-outs).
The chain cover is the Hebie Chainglider - apparently very effective at keeping the chain clean.
http://www.thorncycles.co.uk/forums/ind ... 5#msg18935
drubie
Postby drubie » Mon Apr 30, 2012 12:32 am
Belt drive maybe? Would require a new bike but no more dust issues.
eeksll
Postby eeksll » Mon Apr 30, 2012 12:45 am
IME,
finish line dry lube - sticky, thick, dirty, impossible to wipe off
RnR Gold - messy application, the stream while turning the cranks, black spots everywhere, I found I could not get it too last, others on the forum have been quite successful with it
EDIT: i meant pro link not tri flo
pro link - makes the chain feel smooth, quiet and slick. Is not DRY, anytime I touch the chain i have to wash my hands, easy to wipe off before next application (not sticky), last longer than RnR gold, not as long as squirt. I use this on the roadie
Squirt Lube - seems to last the longest, does not seem to work too well in the wet, it is dry, requires an initial degrease which a mate did :), I use this on the commuter
Purple Extreme - I have a bottle never tried it cause I have to degrease the chain first, I'll probably use this on the mtb if I ever ride it enough to require the first lube :)
RnR Gold tells you to wipe it off as much as you can, which I did, but I am starting to wonder if I used it like how I use the other lubes (wipe before application and dont wipe after) it might last longer.
I don't actually purposefully use different lubes for different bikes, its just kinda worked out that way.
BoardRider
Postby BoardRider » Mon Apr 30, 2012 4:50 am
+1 RnR Gold ,but after this thread I might try some others when I am back riding. I agree with an previous posts that gear changes are silky smooth with RnR Gold .The crud does build on the jockeys wheels but I expect that with all lubricants.
I guess though I haven't tried any others or had the need to change.
Board Rider
"Motivation is what gets you started. Habit is what keeps you going."
Source Unknown
Postby toolonglegs » Mon Apr 30, 2012 5:16 am
Been on extra virgin olive oil gmfor a few months now... Have used it in kysrium free wheel mechs for a while so thought I would use on the chain... Super cheap and works fine for me.
gururug
Postby gururug » Mon Apr 30, 2012 6:29 am
Depends how often you want to maintain your chain. I use thinner lubes for my faster bikes and thicker lubes for my "all weather" bikes. Not really an issue, feel for the MTB crowd though :roll:
Comedian
Postby Comedian » Mon Apr 30, 2012 7:13 am
I can't find much between them. With PE I still get a noisy chain after only a couple of hundred k's at best. What's more, if I do a full degrease and then PE it will be <100 k before it's rattling away. After the second oil it does go further.... at best 200k. The bike shop told me that I'm too sensitive and that a little bit of noise is normal... maybe I'm being harsh on it.
None the less it's at least as good as everything else I've got. Also, the dry lubes definitely run cleaner I've noticed. That's an advantage in dry dusty weather.
greyhoundtom
Postby greyhoundtom » Mon Apr 30, 2012 8:24 am
After a lot of experiments and spending too much money on bike specific chain lubes, I have gone back to what I started with, and that is Nulon engine treatment mixed 50/50 with 3-in-one multipurpose household oil.
Yes the chain goes black, but a quick wipe after every second ride and applying the mixture to the chain links once a month, and giving it a good wipe after application is doing a great job.
Parrott
Postby Parrott » Mon Apr 30, 2012 5:43 pm
Prolink gold.
Tried RnR gold but the driveline was very noisy using it. I figured more noise = more metal on metal contact and more wear so stopped using it.
G-Ride
Postby G-Ride » Mon Apr 30, 2012 5:50 pm
Surprised no-one has mentioned Morgan Blue products - a current fave.
G.
wurtulla wabbit
Postby wurtulla wabbit » Mon Apr 30, 2012 6:11 pm
I use lithium spray grease on all my bikes,even dirt bikes.
Goes dryish and doesn't attract debris and dirt/dust like wet lubes.
Stays on for a very long time.
high_tea
Postby high_tea » Mon Apr 30, 2012 9:14 pm
I've been tring Rimula-X. It's your diesel's preservation, you know! I happened to have several litres of Rimula-X lying around with no earthly use for it. So far, so good. If it pans out, my chain-lube expenditure for the foreseeable future will be zero. Fingers crossed...
I've been tossing up mixing it with metho or something to thin it out, the better to get into the rollers. I expect the metho would evaporarate, leaving oily goodness. Least that seems to be the theory that Rock n Roll Gold (what I previously used) operated on, only the lubricant was in suspension. Oh, and I'm sure the fluid was something far scarier than metho. Anyway, has anyone ever tried this sort of thing?
Thoglette
Postby Thoglette » Mon Apr 30, 2012 10:48 pm
eeksll wrote:Squirt Lube - seems to last the longest, does not seem to work too well in the wet, it is dry, requires an initial degrease which a mate did :), I use this on the commuter
I was horrified to discover I was using a poll-compatible lube, but Squirt it is. Today.
It just happened to be the only wax-in-solvent/suspension lube in the shop last time I had the need.
Never mind, I am doing my mea cuplas and melting paraffin as I type to lube my new chain the proper way.
( "Pie Iesu domine, dona eis requiem")
Postby il padrone » Mon Apr 30, 2012 11:05 pm
One way to do it..... if you have the right drivetrain :wink: .
Thoglette
Postby Thoglette » Mon Apr 30, 2012 11:23 pm
Oh Wheely wrote:ISo I have just given up cleaning with scrubbing brushes, solvents, compressed air and more scrubbing and brushing and solvents and relubing and wiping and another 4 or 5 days later the chain and gears are covered in black grinding paste again and then the endless weekly clean and lube and doing that month in, month out, year in and year out......
ImageHave you been using the The ShelBroCo Bicycle Chain Cleaning System (TM) properly?
dynamictiger
Postby dynamictiger » Tue May 01, 2012 8:52 am
As a noob I am finding this thread very interesting.
What is wrong with WD 40 as a degreaser? I thought it was quite a good choice for a weekly cleaner with a proper clean about once a month.
Although I must admit to using a bit of synthetic oil mixed with 3 in 1 as I had it hanging about. Interested to see who is using what particularly with the wet weather coming up.
mitzikatzi
Postby mitzikatzi » Tue May 01, 2012 9:55 am
dynamictiger wrote:snip..
What is wrong with WD 40 as a degreaser? ...snip.
WD 40 is a Great degreaser.
The common opinion on forums seems to be that WD 40 is not a very good chain lube. Others disagree and say it works.
After oiling your chain and letting it "soak" for a while make sure you wipe down the outside of the chain with a clean rag to remove any excess oil, it is the oil in the chain that does anything.
Mrfenejeans
Postby Mrfenejeans » Tue May 01, 2012 10:19 am
G-Ride wrote:Surprised no-one has mentioned Morgan Blue products - a current fave.
G.
Have just got some Morgan Blue - Race Lube, after using Rock n Roll Gold for the past 9months. Have to say other than being a totally different type of lube it definitely seems to make everything run a lot quieter and not sure if its the lube but shifting seems to be smoother as well, this is based on a single 40km ride yesterday though so time will tell for me.
moreegolfer
Postby moreegolfer » Tue May 01, 2012 10:36 am
I have used TriFlow, R&R Gold and Finish Line Dry. I bought a can of Finish Line's Cleaner and Lube (blue can) and have used that a couple of times. I really can't tell the difference :roll: . They all seem ok to me.
Nobody
Postby Nobody » Tue May 01, 2012 10:44 am
I've changed to Chain-L from Finish Line Wet. If anything, Chain-L is probably a little bit thicker. Interestingly it smells and looks like automotive 80/90 gear oil. This time I've got a new drive train so I'll see how far I get. Chain-L has had some good reviews.
tallywhacker
Postby tallywhacker » Tue May 01, 2012 10:57 am
I've tried all the usual products (tri-flow, r&r, finishline, squirt.....) but what I find is good value and performs well is McCulloch chainsaw lube mixed with some castrol marine grease cut with wd40
Users browsing this forum: Jmuzz
