9070 RD crash reset
ACT SC600
9070 RD crash reset
Postby ACT SC600 » Mon Jul 04, 2016 5:32 pm
9070 RD Di2 Crash Protection Reset
I transported my bike yesterday and it looks like it has gone into crash mode... i tried to do the crash reset but this hasn't sorted it... the RD dropped to the lowest position and stopped working. Just a bunch of clicking noises from there on.
Then I read about the reset procedure, but it failed to correct the issue. I took a closer look and it appears there's a half clover shaped gear that the servo rotates, and a spring tensioned pin that slips into the grove (see attachment). This is the crash protection feature I guess, which allows the parallelogram to detach from the servo motor in order to keep the motor from being damaged. From what I can tell it looks like the clover gear is out of position--probably from me continuously trying to reset it with no luck. After playing around with it, I think the main groove in the clover gear needs to be about 120 degrees clockwise in the lowest position, aligning with the "JAPAN" text.
Anyway I'm hoping someone can help me figure out how to get it to reset. When I go through the crash reset cycle, the gear rotates about three stops counter-clockwise, then finishes out in the opposite direction which is way out of position to allow the pin to drop in.
Re: 9070 RD crash reset
Postby Duck! » Mon Jul 04, 2016 6:50 pm
Try manually pushing the derailleur in to the low position (outboard is high gear), basically re-crashing it, then try the reset procedure again.
ACT SC600
Postby ACT SC600 » Tue Jul 05, 2016 9:32 pm
No dice :(... any other ideas?
petal665
Postby petal665 » Thu Sep 29, 2016 9:07 am
Did you ever solve this? I have 2 here that have been crashed and won't recover from crash mode.
zariaman
Postby zariaman » Mon May 14, 2018 7:30 pm
I am going crazy with this same issue? Did you fix it or is the RD done?
