Shimano FC-6800 Crank
Newcastle Dave
Postby Newcastle Dave » Mon Jul 24, 2017 1:22 pm
So I had a creaking,clunky sound on the right side on Saturday. I thought it was the peddle and swapped those, but clunk was worse. Had another look and saw that the crank seems to be broken or coming apart. The pedal "spider" (not sure what its called) is raised 1-2 mm away from the chainring
Having removed it, I cant quite figure out how its all put together (much to my mechanic fathers shame, I am a mechanical klutz). I can see four bolts (stupid star bolts, what's wrong with hex screws) seeming to hold the pedal "spider" to the chainring, but these seem to be done up without any movement.
Is that all that hold the two pieces together ? (need to go shopping for a large star driver - anyone know what size these are ?)
Re: Shimano FC-6800 Crank
Postby Duck! » Mon Jul 24, 2017 1:58 pm
The T30 Torx bolts only hold the chainrings on. The crank arms & spider are hollow, each made in two pieces and bonded together - you can see the join all the way around the edge of the inner piece. The large chainring is similarly made in two pieces and bonded together. It's uncommon, but there have been cases of the cranks and rings failing at the bond.
Newcastle Dave
Postby Newcastle Dave » Mon Jul 24, 2017 2:34 pm
Duck! wrote:The T30 Torx bolts only hold the chainrings on. The crank arms & spider are hollow, each made in two pieces and bonded together - you can see the join all the way around the edge of the inner piece. The large chainring is similarly made in two pieces and bonded together. It's uncommon, but there have been cases of the cranks and rings failing at the bond.
Thanks Duck - so if mine look like this (hoping image displays) then I guess it is stuffed.
[insta]https://instagram.com/p/BW6pJlJnKuz/[/insta]
Rang the LBS that I have had previous good dealings with, they quoted $580 but said they had none in stock, nor did Shimano have any listed in Australia.
So looks like I order one from OS (and save heaps)
Last edited by Newcastle Dave on Mon Jul 24, 2017 2:44 pm, edited 1 time in total.
eeksll
Postby eeksll » Mon Jul 24, 2017 2:41 pm
might be best to just go the link
link to photo
Postby Duck! » Mon Jul 24, 2017 3:20 pm
Yes, that appears to be a separating crank arm/spider. It's kaput. If it's less than two years old it will be covered under warranty.
Newcastle Dave
Postby Newcastle Dave » Mon Jul 24, 2017 3:54 pm
Duck! wrote:Yes, that appears to be a separating crank arm/spider. It's kaput. If it's less than two years old it will be covered under warranty.
Nah, its 3 1/2 years old, but only about 18000 km - must be the awesome power I am putting down :D
So how come Wiggle can sell me one for $205 while the LBS says they are over $500 ?
eeksll
Postby eeksll » Mon Jul 24, 2017 8:32 pm
if the wiggle "savings percentage" are to be believed, the full price is $400. So $500 isn't too bad from Aus LBS.
Postby Duck! » Mon Jul 24, 2017 8:52 pm
Local wholesale price is around $300 before taxes and freight.
Lukeyboy
Postby Lukeyboy » Tue Jul 25, 2017 10:43 am
Newcastle Dave wrote:but said they had none in stock, nor did Shimano have any listed in Australia.
Jason. Geoff...
Postby jasonc » Tue Jul 25, 2017 11:29 am
Jason. Geoff...
Newcastle dave- Shimano don't have a spare parts division. They have nice offices instead. Buy it from wherever you need. 18,000kms - was getting time for new rings anyway. So buy a new crank, chain and cassette
GeoffInBrisbane
Postby GeoffInBrisbane » Tue Jul 25, 2017 1:08 pm
Haha. Shimano Australia...stock...yeah...no...whatever it is you are trying to order!
Veloviewer
MS-DOS Phone. For when you want it done right.
Newcastle Dave
Postby Newcastle Dave » Wed Jul 26, 2017 4:58 pm
Well, just because I am a cranky old man, I decided to email Shimano for an explanation.
So I asked them;
1) Why do Shimano not have any stock of this in Australia ?
2) Why is the Australian wholesale price close to 150% more than the retail price overseas ?
They replied
"With Ultegra 6800 series being phased out to make way for the new R8000 series, we have limited availability of remaining FC-6800 cranksets.
Meanwhile, overseas retailers may be quite heavily stocked up; hence their low prices to clear out previous generations and make way for new components.
We are expecting some specifications new Ultegra FC-R8000 to start arriving this week."
I then asked them if they thought running out of stock of the old component before stocking the new component was their idea of good customer service (I told you I am an old cranky bastard)
They then replied;
"Actually, I’ve just had a look and we just have literally just received FC-6800 in 172.5, 52/36.
Meanwhile, the new model FC-R8000 is available and actually a few dollars cheaper than the 6800 model."
I bet its still a lot more expensive than I got from Chain Reaction
Postby Duck! » Wed Jul 26, 2017 7:25 pm
Much as I love the products, Shimano's local subsidiary needs a firecracker up its collective bum.....
What is true though is that 6800 will become harder to get as it's phased out for R8000, given the cross compatibility between the two groups.
Lukeyboy
Postby Lukeyboy » Wed Jul 26, 2017 9:06 pm
Must have started that phase out back in 2015 haha.
Postby jasonc » Wed Jul 26, 2017 9:27 pm
It started before the phase in of the product. Easier that way
nevyn
Postby nevyn » Wed Sep 27, 2017 7:57 pm
My understanding was that r8000 cranks were not compatible with r6800 fd due to do different spacing and offset.
Postby Duck! » Wed Sep 27, 2017 9:17 pm
The official word from Shimano is that it depends on the frame, specifically seat tube thickness. The R8000 small chainring is a little further inboard than 6800, the large ring is on the same chainline. On frames with a thicker seat tube and particularly with braze-on mount FD, the 6800 may not be able to swing in far enough to properly tune on the small ring. The R8000 has a bit more inward travel to suit the inboard ring. In most cases the 6800 will be OK, but for absolute certainty it's a good idea to pair the R8000 crank & FD.
