Dura Ace shifter repairs
tomee
Postby tomee » Wed Aug 30, 2017 9:09 am
i've got a DA shifter which has had the inner trigger bent after a light bingle
Does anyone know if these can be removed and changed? I was thinking of bending it back but as you can see in the photo below it has a stress fracture.
I have a spare ultegra shifter which i could use parts from
Re: Dura Ace shifter repairs
Postby Duck! » Wed Aug 30, 2017 9:49 pm
What series shifter?
usernameforme
Postby usernameforme » Thu Aug 31, 2017 8:32 am
Looks like a 9000 from the placement of the DA logo, IIRC the 9001 series have the logo placed below the groove?
tomee
Postby tomee » Thu Aug 31, 2017 12:16 pm
yup 9000 series
Postby Duck! » Fri Sep 01, 2017 12:31 am
Unfortunately that part of the shifter mechanism is not replaceable, as it's built into the hood assembly.
tomee
Postby tomee » Fri Sep 01, 2017 10:53 am
bugger.
looks like i have to break it and metal epoxy it back
ValleyForge
Postby ValleyForge » Fri Sep 01, 2017 9:22 pm
tomee wrote:i've got a DA shifter which has had the inner trigger bent after a light bingle
Shimano & spare parts always gives me a laugh. Sometimes I swear it's a conspiracy - firstly the part isn't made. If it is, no-one in the LBS can tell you if it's available in AU, or what the lead time is - because Shimano AU doesn't know. And then it arrives and no-one is sure if it is the correct one, as there are 5 different versions which you tell apart by where the sticker is!
Ha ha ha! Cookies on dowels.
lunar_c
Postby lunar_c » Sat Sep 02, 2017 11:16 am
An engineer friend once told me that I shouldn't be afraid to attempt to fix something because "it's already broken".
If you have a spare ultegra shifter of the same era try and see what parts are compatible between the two. I've done this with earlier series shifters - however I suspect the other posters are correct.
At the very least you may be able to swap the DA shifter blades/brake lever into the ultegra body?
jackthelad
Postby jackthelad » Sun Sep 03, 2017 2:58 pm
Try Petra Cycles in the uk, for Small parts
used them before
pay for shipping, but they carry the complete sram spare parts catalogue and possibly the shimano one too
SantaCruz HighTower LT
SantaCruz Blur XC Carbon
Kona Kula Supreme
Ribble Rd Bike
Users browsing this forum: 10speedsemiracer, Mickey1980
