Shimano road shifter lubricant
rtnicho
Postby rtnicho » Wed Sep 06, 2017 8:58 am
Hi all
I have just had to clean out the dried crusty grease from a pair of 6700 shifters using a good spray /soak / spray with WD40. They now work perfectly. What's the current thinking about re-lubrication? I've used TF2 spray in the past with good effect but haven't had to do this for a few years so wondered if the world had moved on a bit.
Tim
Re: Shimano road shifter lubricant
Postby Tim » Wed Sep 06, 2017 9:53 am
Art's Cyclery recommend aerosol Boeshield T9;
http://www.artscyclery.com/learningcenter/cleaningshifters.html
http://abbotsfordcycles.com.au/boeshield-t-9-is-space-age-spray-for-bicycles-12oz_p3546
It isn't cheap but goes a long way. I've had a 12oz can for three years and it's still nearly full. Very occasional (annual) use on shifters and more regularly on caliper and derailleur pivot points. Good rust protection on steel too.
Boeshield is recommended for chains but I don't like it for chain lube. Doesn't stay put very long and goes cakey.
Postby Duck! » Wed Sep 06, 2017 10:47 am
Shimano recommend a dry lube. I use a silicon spray which does the job well.
ValleyForge
Postby ValleyForge » Wed Sep 06, 2017 11:06 am
I used silicon garage door spray once on the kid's Shimano shifters.
Never again. I use a PTFE spray I got from the locksmith.
Ha ha ha! Cookies on dowels.
martin_12
Postby martin_12 » Wed Sep 06, 2017 11:45 am
Power Lube works well.
eeksll
Postby eeksll » Wed Sep 06, 2017 9:15 pm
so for those of you who use the spray, do you give it the wd-40 treatment first? or just go straight to the spray lube?
ValleyForge
Postby ValleyForge » Wed Sep 06, 2017 9:53 pm
Just a spray maybe once a year. Harder in the internally routed bikes though.
Most important sections are unsurprisingly, the handlebar curves and the RD lead-in.
headasunder
Postby headasunder » Thu Sep 07, 2017 9:23 am
Wd40 followed by lps1 if your going to use silicon spray don't do it above the kitchen floor.
10speedsemiracer
Postby 10speedsemiracer » Thu Sep 07, 2017 5:55 pm
Mmm, SunTour
Mububban
Postby Mububban » Fri Sep 08, 2017 2:06 pm
ValleyForge wrote:I used silicon garage door spray once on the kid's Shimano shifters.
What's the difference? Does the silicon go sticky/attract dust over time?
ValleyForge
Postby ValleyForge » Fri Sep 08, 2017 9:51 pm
I don't think so - this was immediate. Gummed it up so I flushed it out with brake cleaner spray. The locksmith spray is called "SuperLube".
On the road bikes (Campy OEM cables) after about the first 2000km with new cables I strip them out and fill them full of red PTFE grease using a grease gun. Makes a mess but I never need to lube them again.
