5600 front shifter broken?
eeksll
Postby eeksll » Sun Sep 24, 2017 1:12 pm
Hello, is my front 5600 shifter gone beyond repair/fixable? Did some googling seemed to suggest it is likely gone beyond repair.
Had a long period where shifting from big to small chainring, the paddle wouldn't always engage, needed to push the paddle multiple times before it engaged/clicked.
Changed cable (it wasn't frayed anyway) still occurred, so yesterday attacked it with Inox spray, while i was spinning the cranks and spraying and trying to work the lever to get the oil to penetrate more places, I heard a louder than usual click/clunk when shifting.
now its stuck in the big chain ring position and the paddle never engages the click, it still springs back.
Re: 5600 front shifter broken?
Postby Duck! » Sun Sep 24, 2017 6:44 pm
It's a known issue with the first two or three years' production 5600s, because they were designed to be used for both 2x and 3x shifting. If the 2x tuning isn't absolutely spot on, the shifter can begin to go into the third gear position and jam, eventually leading to failure of the shifter mechanism.
Short version: it's dead.
eeksll
Postby eeksll » Sun Sep 24, 2017 9:55 pm
thanks for the confirmation. :cry:
Postby Duck! » Mon Sep 25, 2017 12:32 am
For the benefit of others, the same issue also affected 4500 Tiagra and 3400 Sora levers; in all three cases the problematitic levers will have the base "xx00" product designation. They were all updated in 2009 for separate 2x & 3x shifters, although the 3x models are actually the original units renumbered as "xx03"; the 2x-specific models will have an "01" number.
eeksll
Postby eeksll » Sun Oct 08, 2017 11:24 pm
so i finally got around to this today. put the 53/39 with only 39 chainring on the bike and thought I'd remove the cable as well.
I cut the inner and now there is a bit poking through, is there anyway to release the mechanism to the small ring so I can remove the cable properly?
Postby Duck! » Mon Oct 09, 2017 12:14 am
Not that I've discovered.
eeksll
Postby eeksll » Mon Oct 09, 2017 1:34 pm
thanks, Ill just have to attack it with some better snips rather than the cable cutters.
