Weeping caps on suspension fork legs
crabcake
Postby crabcake » Tue Oct 03, 2017 12:48 pm
Does anybody know what these plastic caps on my Suntour suspension forks are for? The lower one is on both fork legs, the upper one is only on the right leg. Occasionally there seems to be oil weeping out of the lower ones which is attracting dirt, but I don't know why they are weeping or if I should be concerned.
crabcake
Re: Weeping caps on suspension fork legs
Postby crabcake » Thu Oct 05, 2017 9:43 pm
Forks are SR Suntour NCX-D, hydraulic w/lock-out, 63mm travel.
crabcake
Postby crabcake » Wed Oct 18, 2017 9:39 pm
The caps hide threaded holes, the larger holes are for fender stays, smaller holes only on the right leg are for cable holders when running a dyno hub. The oil was whatever they used to protect the threads.
