Sleeve in seatpost clamp neccesary
eeksll
Postby eeksll » Sun Oct 08, 2017 11:38 pm
what does this sleeve do? do I need it? I put a old quick release seat clamp on another bike and this piece is missing, can I put something else there if its required?
Re: Sleeve in seatpost clamp neccesary
Postby Duck! » Mon Oct 09, 2017 12:11 am
That's your clamping surface! Without that steel shim, you'll have two comparitively soft aluminium surfaces rubbing against each other, which will wear the clamp out much faster.
eeksll
Postby eeksll » Mon Oct 09, 2017 1:35 pm
just as well, the seat clamp isn't clamping anyway
