chainring compatibility
hamishm
Postby hamishm » Thu Oct 19, 2017 5:21 pm
I'm looking for the cheapest way to replace the worn chainrings on my 6700. Can I put 5700 chainrings on my 6700 crankset? (Yes they'll be the same size, 50 and 34) I'll replace both.
Tim
Re: chainring compatibility
Postby Tim » Thu Oct 19, 2017 5:26 pm
Yes. But the colour won't match.
Quite often it is cheaper to replace the entire crankset.
Postby Duck! » Thu Oct 19, 2017 5:53 pm
5700 rings aren't that expensive because they're not hollow. They'll fit but won't look pretty because the spider shaping is different.
hamishm
Postby hamishm » Thu Oct 19, 2017 6:31 pm
Duck! wrote:5700 rings aren't that expensive because they're not hollow. They'll fit but won't look pretty because the spider shaping is different.
It's only for the trainer so I don't really care. $60 for the pair for 5700 rings, versus about $150 for a new 5800 crankset. The 6700 rings would be about $90 for the pair if they were available.
4700 would work too right? Only $98 for a whole crankset.
Postby Duck! » Thu Oct 19, 2017 8:39 pm
Any of Shimano's 2-piece cranks will work, because they all share the same critical bottom bracket dimensions for spindle diameter and assembled width.
