Cassette Cogs in Wrong Order
peter
Postby peter » Wed Nov 01, 2017 7:33 pm
So I have ridden more than 2000km since the last time I dismantled the cassette for cleaning, I always get this strange feeling that down shifting sometimes feels like up shifting.
Mystery solved today! An unintentional discovery, I installed one of the cogs in the wrong order. :lol:
biker jk
Re: Cassette Cogs in Wrong Order
Postby biker jk » Wed Nov 01, 2017 8:01 pm
There's a spacer missing as well between those cogs in the wrong order.
koshari
Postby koshari » Wed Nov 01, 2017 8:13 pm
peter wrote:So I have ridden more than 2000km since the last time I dismantled the cassette for cleaning, I always get this strange feeling that down shifting sometimes feels like up shifting.
iam surprised it shifted at all! (its not april the 1st by any chance btw?)
Bunged Knee
Postby Bunged Knee » Wed Nov 01, 2017 8:20 pm
This is qualified as a I`m a champion bike mechanic. :)
peter
Postby peter » Wed Nov 01, 2017 8:39 pm
biker jk wrote:There's a spacer missing as well between those cogs in the wrong order.
Spacer is there but not showing in that camera angle.
peter
Postby peter » Wed Nov 01, 2017 8:42 pm
koshari wrote:iam surprised it shifted at all! (its not april the 1st by any chance btw?)
It shifts smoothly, otherwise would have investigated and discovered the stuff up earlier. :D
uart
Postby uart » Wed Nov 01, 2017 8:44 pm
I'm definitely not seeing it.
Bunged Knee
Postby Bunged Knee » Wed Nov 01, 2017 8:57 pm
Agreed. No spacer between the 6th and 7th cassettes.
Postby trailgumby » Wed Nov 01, 2017 10:15 pm
Agreed, although I can see why people thing it's not. Combination of the out-of-sequence cog and camera angle.
uart
Postby uart » Wed Nov 01, 2017 10:21 pm
trailgumby wrote:Agreed, although I can see why people thing it's not. Combination of the out-of-sequence cog and camera angle.
Yes, it's a pretty good optical illusion. :D
Postby Duck! » Wed Nov 01, 2017 11:00 pm
The chain is sitting over one spacer, and the other is partly hidden by the out-of-sequence smaller sprocket.
I have the occasional dumb moment like this, usually the next sprocket after a set pinned to a spider; the spider includes the spacer to the next sprocket, but I'll slip an extra spacer on where it shouldn't be, then end up with two sprockets & no spacer. And I do this for a living! :-P Gets discovered in short order though, and is usually a signal to crank up the coffee machine. :-P
peter
Postby peter » Wed Nov 01, 2017 11:03 pm
If a picture is worth a thousand words, then a video is worth a million. :D
I guest the situation could have illustrated more clearly by simply taking a top down picture.
silentC
Postby silentC » Thu Nov 02, 2017 8:48 am
Classic!
When I take mine off to clean or whatever, I thread a shoe string through the whole cluster and tie a knot in it so that it's not possible to get anything out of order.
"If your next bike does not have disc brakes, the bike after that certainly will"
- Me
Postby find_bruce » Thu Nov 02, 2017 9:27 am
Interesting optical illusion - you can see the spacer through the holes in the cog, but the perspective makes it look like its missing
eeksll
Postby eeksll » Thu Nov 02, 2017 9:49 am
weird optical illusion, I was convinced there was no spacer between those 2 cogs as well
Postby trailgumby » Thu Nov 02, 2017 10:01 am
Duck! wrote: And I do this for a living! :-P Gets discovered in short order though, and is usually a signal to crank up the coffee machine. :-P
:lol: :lol: I can imagine the internal dialogue at this particular moment :lol:
koshari
Postby koshari » Thu Nov 02, 2017 12:42 pm
eeksll wrote:weird optical illusion, I was convinced there was no spacer between those 2 cogs as well
as was i, on closer inspection you can see top of the the plastic spacer material through the holes in the nearest sprocket.
hamishm
Postby hamishm » Fri Nov 03, 2017 12:48 pm
Yikes, I'm going to check the bikes right now. I have this feeling too some times.
Postby Duck! » Fri Nov 03, 2017 1:50 pm
On a divergent but related note, be exceptionally careful when handling Campagnolo cassettes, because for reasons known only to them, 10 & 11-sp. cassettes have unequal sprocket spacings, therefore different thickness spacers. If you get them in the wrong order the shifting will go very haywire.
Sharkey
Postby Sharkey » Fri Nov 03, 2017 4:29 pm
Duck! wrote:On a divergent but related note, be exceptionally careful when handling Campagnolo cassettes, because for reasons known only to them, 10 & 11-sp. cassettes have unequal sprocket spacings, therefore different thickness spacers. If you get them in the wrong order the shifting will go very haywire.
I recently purchased a Miche cassette for my 11 speed Campag bike along with a new wheel for my Shimano bike. The cassette had broken out of its packaging and had not been zip-tied together. I had to completely dismantle the box to find all the 20+ cogs and spacers and then put it back together in the correct order. Sounds like it was lucky that it worked first time.
Users browsing this forum: caneye, Waccofozzy
