Ferrule for cable through 'eyelet' thingy.
member054
Postby member054 » Sat Dec 02, 2017 3:29 pm
Hello,
I'm looking for a solution for a rear derailleur cable outer that goes through the chainstay eyelet. I don't know its technical name is... but this bit:
The cable outer is a snug fit and there is no difference of inner width through the eyelet, so nothing to stop the outer going through.
Any ideas on how what/how I can use to fix this?
Thanks!
Cardy George
Re: Ferrule for cable through 'eyelet' thingy.
Postby Cardy George » Sat Dec 02, 2017 3:47 pm
To me that looks like it's designed for a full length cable outer, i.e. from shifter to derailleur, not the just the segments........
ironhanglider
Postby ironhanglider » Sat Dec 02, 2017 3:54 pm
You need a Step Ferrule
There are lots of variations on the theme.
Cameron
member054
Postby member054 » Sat Dec 02, 2017 3:56 pm
ironhanglider wrote:You need a Step Ferrule
Cameron
Perfect, thanks :o You guys watch these forums like hawks!
darkhorse75
Postby darkhorse75 » Sat Dec 02, 2017 4:35 pm
That cable stop is known as a 'divers helmet" and as noted above you'll need a step down ferrule that fits snugly for a nice clean cable line.
P!N20
Postby P!N20 » Sat Dec 02, 2017 9:19 pm
Also, take your frame and cable housing in to your LBS so you can get one that fits snug, as there are various sizes. If you're buying online...good luck.
member054
Postby member054 » Sun Dec 03, 2017 2:16 pm
P!N20 wrote:Also, take your frame and cable housing in to your LBS so you can get one that fits snug, as there are various sizes. If you're buying online...good luck.
I checked the open local stores today and it wasn't something easily stocked - but I saw an expanded view of the Campagnolo Ultra Shift cable kit (which I need anyhow) from an online retailer and it shows a step ferrule... so I'll contact them for confirmation.
Thanks again for help!
P!N20
Postby P!N20 » Sun Dec 03, 2017 4:00 pm
^ Bad news. The Campy ultra shift cable set does not come with a stepped ferrule. It used to, but doesn't anymore.
Also, the normal ferrules that are included in that set are too large for the cable housing, IMO. I ended up getting replacement ferrules.
member054
Postby member054 » Sun Dec 03, 2017 5:54 pm
P!N20 wrote:^ Bad news. The Campy ultra shift cable set does not come with a stepped ferrule. It used to, but doesn't anymore.
You champion! That probably explains why the cables & ferrules that came with the levers didn't have the step one. The ferrules that came in the box are snug for the brake outers but yes, a bit wiggly for the gear outers.
I've found an online retailer in Perth that has Shimano's SIS-SP40 and its dimensions look right - will grab that:
https://www.tbe.com.au/products/shimano-gear-outer-cap-sp40-4mm-ste/132049/
Users browsing this forum: Bing [Bot], CKinnard
