Chain jammed inside front chainring and downtube ...
Rural Rider
Postby Rural Rider » Mon Jan 01, 2018 11:09 pm
Cheers all.
Got back from a ride today and noticed when putting the bike away that the chain has jumped off the small cog of the front chainring and is good and jammed against the downtube. I don't want to do damage to the Carbon frame or paint if I can help it (2017 Trek Emonda SL6) ... it won't budge with my fingers. The chain is sitting midway on the rear cassette - I'd appreciate some good advice on getting it clear and re-seated.
I'm assumung I'll just need to remove/adjust the chainring and crank arms yes?
Thanks gents! 8)
2016 Specialized Allez e5 Sport
jackthelad
Re: Chain jammed inside front chainring and downtube ...
Postby jackthelad » Tue Jan 02, 2018 1:12 am
Sram is one 8 mm allen key easy job ,
undo retighten once chain is loose
shimano, do you have the tension cap tool?
undo the bolts , release the black wafer thing in the cranks, release the tension in cap,
reverse to retighten , me i just do one good yank, it be free
look at your shifting when you have it out
SantaCruz HighTower LT
SantaCruz Blur XC Carbon
Kona Kula Supreme(Retired/Spare)
Surly Karate Monkey
Ribble Rd Bike
Postby trailgumby » Tue Jan 02, 2018 12:59 pm
I'd recommend a K-Edge chain keeper. Bolts on over the top of your FD using a longer bolt. Due to my hybrid 10/11spd front setup, I used to drop the chain once every 2-3 rides. Not anymore.
https://www.google.com.au/search?rlz=1C ... 8bEBS4s6P0
jackthelad
Postby jackthelad » Tue Jan 02, 2018 1:59 pm
Go Single ring.... or chain keeper, whichever works best for u
Surly Karate Monkey
Ribble Rd Bike
headasunder
Postby headasunder » Tue Jan 02, 2018 6:14 pm
+1 to the chain keeper it removes fear factor, very ocassionly when I down shift up front there is a clatter as the keeper does it job certainly beats the alternative
Kronos
Postby Kronos » Wed Jan 03, 2018 9:40 pm
A back pedal should usually unjam something like this.
Baalzamon
Postby Baalzamon » Wed Jan 03, 2018 11:35 pm
BV great ride, had this happen very very badly to a rider and had to take the cranks off to fix it. Paint was damaged and a bit of a gouge on the carbon.
Rural Rider
Postby Rural Rider » Thu Jan 04, 2018 12:45 am
Thanks for the tips gents!
I haven't the tools to fix this at home myself right now so will take it to the local Mech to get sorted and will definitely be installing a chain catcher as recommended! I can see there is already a little paint removed where the chain is jammed but hopefully no gouging to the Carbon Frame ... I don't want this happening again - and while usually OCD about damage or blemishes on Bikes, it's down where you can;t see a thing. Local Bike dealer is the Dealer I bought from so perhaps they have a little touch up paint on hand as well.
Cheers RR.
RobertL
Postby RobertL » Thu Jan 04, 2018 10:28 am
If you can't find the right touch up paint, try nail polish. It comes in a million different colours and is great for touching up those sort of chips.
Rural Rider
Postby Rural Rider » Fri Jan 05, 2018 12:38 am
Good tip on the fingernail polish ... tough for me though I'm not sure it will be easy to find such an odd shade of flat metalic grey/black DNISTER BLACK for my Trek. Worst come to worst I could get a mix from a spray shop to a price.
jackthelad
Postby jackthelad » Sun Jan 07, 2018 3:46 pm
Just use clear nail polish, its just to seal the frame, not get fancy
Surly Karate Monkey
Ribble Rd Bike
