Garmin 520 Intermittently Loses Satellites
mogwaiboi
Postby mogwaiboi » Thu Mar 22, 2018 8:42 pm
Hi All
My Garmin 520 (out of the blue) has started to intermittently lose satellite reception during rides, for minutes at a time. It happens in open areas. Latest firmware 12.50, I've reset it and even formatted it, but the issue still persists. Any ideas (besides buying a Wahoo Elemnt Bolt)?
Thanks!
In search of up - Hells 500
Re: Garmin 520 Intermittently Loses Satellites
Postby RonK » Thu Mar 22, 2018 11:16 pm
Are you using a GoPro?
mogwaiboi
Postby mogwaiboi » Fri Mar 23, 2018 8:13 am
RonK wrote:Are you using a GoPro?
No I'm not
Shred11
Postby Shred11 » Fri Mar 23, 2018 8:19 am
Sometimes electronics on your bike can interfere with reception of the GPS signal.
If you have a light on the front of the bike, see if switching it off (or moving it, or substituting a different light etc) fixes the problem.
RobertL
Postby RobertL » Fri Mar 23, 2018 11:41 am
Shred11 wrote:Sometimes electronics on your bike can interfere with reception of the GPS signal.
Yeah - I was given a basic video camera for Xmas. When I mounted it on my bike it blocked the GPS reception on my Garmin. Not totally, but I had trouble acquiring satellites, and they'd drop out occasionally. I moved the video camera as far away and as low as I could (sensibly) and it seems to have worked.
mogwaiboi
Postby mogwaiboi » Sat Mar 24, 2018 8:56 pm
Unfortunately it occurs without any lights on the bike :cry:
1Rowdy1
Postby 1Rowdy1 » Sun Mar 25, 2018 12:09 pm
I have had the same problem, started on Tuesday
mogwaiboi
Postby mogwaiboi » Mon Mar 26, 2018 8:41 pm
1Rowdy1 wrote:I have had the same problem, started on Tuesday
Interesting, I read somewhere that some people were having issues with Glonass recently so they turned that off and just left GPS on. I'm going to try that and see if it makes any difference...
