Rounded hex socket
2sharp
Rounded hex socket
Postby 2sharp » Sun Mar 25, 2018 9:19 pm
So this guy I know was going to pull apart his derailleur cage this weekend to have a ruddy good clean of his jockey wheels.
But, turns out the hex socket on the screw that holds it all together has mysteriously become rounded.
If you were to advise him on how to proceed, what would you say?
Derny Driver
Re: Rounded hex socket
Postby Derny Driver » Sun Mar 25, 2018 9:32 pm
Dont proceed :) Leave it
There is a wealth of ideas on Youtube. "How to remove a stripped hex bolt"
Thoglette
Postby Thoglette » Sun Mar 25, 2018 9:41 pm
Cutting wheel. Or drill.
Duck will explain.
WyvernRH
Postby WyvernRH » Mon Mar 26, 2018 8:38 pm
Drill a pilot hole in the middle of the rounded hex in the bolt and use a stud extractor.
eeksll
Postby eeksll » Mon Mar 26, 2018 9:28 pm
I have heard jamming a torx driver in the head can work. Got nothing to loose if you have the torx tip.
if the screw shows on the other side (like most do on those cages) hit it with a small drill bit from the other side, wont need a reverse bit or extractor. may need to be a bit careful the bit doesnt slip.
make sure they have the spare screw / replacement before removing it.
Users browsing this forum: The Great Boffo
