Cassette worn or dirty?
Couchy
Postby Couchy » Sat Sep 08, 2018 9:42 pm
Hey guys
Having some trouble shifting is this cassette worn out or just dirty?
Thanks for help
Re: Cassette worn or dirty?
Postby find_bruce » Sat Sep 08, 2018 10:06 pm
You need to use the image URL for the image tags to work
https://ibb.co/eybGX9
Couchy
Postby Couchy » Sat Sep 08, 2018 10:52 pm
Thanks for letting me know Bruce
NASHIE
Postby NASHIE » Sat Sep 08, 2018 11:15 pm
High gears (small sprockets) look flogged out which should result in jumping in gear, which may seem like shifting issues. New cassette and chain in order. Service your cables aswell as poor shifting can be cable related.
Postby Duck! » Sat Sep 08, 2018 11:36 pm
NASHIE wrote:High gears (small sprockets) look flogged out ....
No, they're fine. The combination of the shifting tooth profiles and the tight sprocket radius can make the small gears look badly worn, when in fact they're usually the least worn of the lot. The 3rd & 5th largest (and presumably the 4th, but can't tell because the chain is on it) sprockets are showing a bit of wear, but not excessive. The chain has seen better days and should be replaced ASAP. The current degree of sprocket wear should be OK with a new chain.
As mentioned above, check the cables; they do stretch over time, which degrades the shifting, and depending on quality can corrode, which will incrrease friction and also degrade the shifting.
10speedsemiracer
Postby 10speedsemiracer » Sun Sep 09, 2018 4:04 am
Much as what Duck has said, I'd probably only add that the rear derailleur hanger should be checked for tightness onto the frame mounting point, and redo the cable/cable housing...also that chain looks loosey-goosey but I think someone already said that.
Mmm, SunTour
Couchy
Postby Couchy » Sun Sep 09, 2018 11:58 am
Thanks for the advice guys. New chain ordered and will check the cables.
