Mechanical disc brake set up
tez001
Postby tez001 » Sat Sep 15, 2018 12:43 pm
I've never been 100% happy with the disc brakes on my commuter.
It came with Tektro calipers and rotors. I upgraded the calipers to TRP Syphre's and Shimano resin pads. This made a marginal improvement.
Im now thinking that changing the cables to compressionless or the rotors / pads may improve the braking?
The brake outer is currently Jagwire CGX-SL. Would I be better off changing the cable to compressionless, or upgrade the rotors and pads, or both?
baabaa
Re: Mechanical disc brake set up
Postby baabaa » Sat Sep 15, 2018 12:47 pm
Can you name and shame your brifters or levers?
tez001
Postby tez001 » Sat Sep 15, 2018 12:59 pm
baabaa wrote:Can you name and shame your brifters or levers?
Doh, left that out, Tiagra 4700.
