Shimano XTR brakeline inserts and olives
open roader
Postby open roader » Tue Sep 18, 2018 7:59 pm
Just a quicky - I'm a complete novice regarding the intricacies of the Shimano XTR component line up.
I have a set of current model M9000 XTR brakes (2nd hand) and am building up an internally routed MTB frame.
I have successfully routed the rear brake line through the frame and now need to re-fit an insert and olive to the end of the hose.
Does anyone know :-
1) what is a good tool to use to trim the end of the brake hose nice and square? (I don't own a pair of proper bicycle cable snips....)
and
2) Is the Shimano BH59-BH63 inset and olive combo compatible with current XTR brake levers? (coming from Campag. gruppo background I simply don't trust universality across different component levels :-)
MichaelB
Re: Shimano XTR brakeline inserts and olives
Postby MichaelB » Tue Sep 18, 2018 8:41 pm
Really sharp knife if you don't want to buy the tool.
Shimano Techdocs are your friend. Look up the exploded views and check the part numbers. They are a great resource and easy to use.
open roader
Postby open roader » Tue Sep 18, 2018 9:33 pm
MichaelB wrote:Really sharp knife if you don't want to buy the tool.
Excellent - just worked it through Techdocs - I need the SM-BH90-SBM kit!
Cheers!
Postby Duck! » Wed Sep 19, 2018 12:57 am
As MichaelB says, a really sharp knife (preferably in conjuction with a good square edge to cut against) will do the job to cut the hose. M980-onward XTR (and down at least to M666 SLX & possibly M615 Deore for anyone else wondering) uses the BH90 hose, which has a smaller bore/thicker wall than BH59/63 hose, so needs the barb insert to suit. The olive is shared with all Shimano hoses, because the outside diameter is the same.
You'll also need to ram the barb into the hose, which can be difficult because by necessity is is a very tight fit. Shimano provide clamping blocks (which double as a cutting guide) that allow you to secure the hode in a bench vice without crushing the hose, but you probably didn't get these with a second-hand brake set; clamp the hose in the blocks and use a hammer to tap the barb in until it;s snug with the end of the hose. Heating the hose slightly to soften it can help with getting the barb in. If you feel like lashing out, Jagwire do a really awesome tool for driving barbs in.
open roader
Postby open roader » Wed Sep 19, 2018 7:30 am
I have the clamping blocks and a vice so a decent box cutter with a new blade will do me. Many thenks Duck - I have the updated barbed insert kit ordered and on it's way..........!
MichaelB
Postby MichaelB » Wed Sep 19, 2018 10:57 am
Cheers!
:lol: The Shimano Techdocs are a GREAT resource. Have used them many times
Sometimes, you don't need the whole hose kit.
I've often bought just the barb and olives locally (from Pushys). Do a google search on the Shimano part numbers and you'll be surprised what turns up. The parts are usually a couple of $$ each.
Of course, if you need the hose, then the kit is the way to go.
open roader
Postby open roader » Wed Sep 19, 2018 4:46 pm
Yeah, I ordered just the insert and the olive - from Pushy's - already dispatched - quite refreshing really.........
Users browsing this forum: WyvernRH
