Removing herdened gel from frame
bianchi928
Postby bianchi928 » Tue Sep 25, 2018 3:31 pm
Hi Brainstrust,
I have spilled some energy gel onto my carbon frame, didn't realise and now it has hardened and solidified.
I have tried the hot flannel to soften it as well as goo remover, all to no avail.
Can anyone please suggest a way to remove it without damaging my frame?
Many thanks.
Stand on my dog I cut off your head
OnTrackZeD
Re: Removing herdened gel from frame
Postby OnTrackZeD » Tue Sep 25, 2018 4:23 pm
bianchi928 wrote:Hi Brainstrust,
Many thanks.
Wrap a wet rag or towel around the effected area for five minutes and it will just come off.
Postby Duck! » Tue Sep 25, 2018 7:58 pm
Hot water and light smear of elbow grease.
bianchi928
Postby bianchi928 » Wed Sep 26, 2018 2:48 pm
Thanks guys, much appreciated.
I have been giving it some thought after the hot water didn't work initially and I am now thinking it's not gel.
Time to investigate.
AUbicycles
Site Admin
Site Admin
Postby AUbicycles » Wed Sep 26, 2018 4:40 pm
If it's not gel... what was making you go faster?
ValleyForge
Postby ValleyForge » Wed Sep 26, 2018 10:54 pm
As long as it's neither DOT brake fluid nor Loctite, I'd ignore it. Can't be too bad.
Ha ha ha! Cookies on dowels.
caneye
Postby caneye » Thu Sep 27, 2018 2:00 pm
hmm .. last year, a similar thing happened to me.
i went over a packet of gel on the way to a group ride meeting point (dark morning).
felt something warm, gooey and sticky splatter over my shin. i thought it was juice or yoghurt.
but after the ride, i could see orange liquid/stain solidifying on the bottom of the frame, wheel and smeared on my leg too.
it was a PITA to remove - tried acetone, simple green, warm, soap, wd40, degreaser, etc ..
i ended up using a US-made concentrated liquid wash that my wife had access to (via direct marketing). it just removed the gel effortlessly, i kid you not.
(it was also the same stain remover i used to get rid of bike grease from my recaro seat)
ValleyForge
Postby ValleyForge » Fri Sep 28, 2018 12:49 pm
Makes you wonder what happens to that HFCS (high fructose corn syrup) when it's in your intestines...
Postby Duck! » Sat Sep 29, 2018 2:02 pm
The hydrochloric acid in your gut makes short work of it.....
ValleyForge
Postby ValleyForge » Sat Sep 29, 2018 2:36 pm
Duck! wrote:The hydrochloric acid in your gut makes short work of it.....
Actually no - it's amylase from your pancreas....
So smear a bit of pancreas on there.
Users browsing this forum: antigee, MattyK
