Blocked Ultegra ST-R8020 hydraulic lever
Eages
Postby Eages » Tue Oct 16, 2018 10:57 am
I’ve recently received a new set of r8020 levers but the right hand appears to be blocked.
I’ve bleed hydro systems plent of times before and set up the left lever fine.
When attempting to use a syringe to injected the fluid into the system I just felt pressure. I tried gravity feed from the lever into the system but nothing flowed through.
I’ve isolated the problem to somewhere between the hose port and the bleed funnel. I’ve even tried to blow air through but couldn’t (doesn’t taste any good).
Is there an obvious thing I’m doing wrong?
MichaelB
Re: Blocked Ultegra ST-R8020 hydraulic lever
Postby MichaelB » Tue Oct 16, 2018 3:17 pm
Not enough info to make sense of it.
I had a similar thing when trying to bleed the hydro's when I first installed them. Turns out I was trying to bleed the rear caliper via the front brake lever .....
When I realised and bled the matching pair (lever and caliper, it worked fine) :-)
