What causes rim brakes to shriek?
Mububban
Postby Mububban » Sat Oct 20, 2018 11:01 pm
My wife bought one of the Aldi folding bikes recently, and the front brake shrieks when stopping. Not the rear, just the front brake. It's brand new, it works, it's not overly grabby or too weak. There's no pulsing of the brake to indicate any warping of the rim. Just a fairly loud shriek that I've personally never encountered on a rim brake before.
Any ideas what might cause this, and what I could try to fix it? Is it just because it's so new, and it'll bed in shortly? I've tried doing repeated braking efforts but the sound hasn't changed so far.
Thoglette
Re: What causes rim brakes to shriek?
Postby Thoglette » Sun Oct 21, 2018 12:01 am
If it's not a design problem or loose bolts, it's most likely toe in. See Sheldon's article
Tamiya
Postby Tamiya » Sun Oct 21, 2018 12:20 am
If I had tools lying out I'd be tempted to try swapping brake pads front to rear.
If all I had nearest to hand was a spray bottle of Windex... use it to clean the rim & brake pads.
Postby bychosis » Sun Oct 21, 2018 6:40 am
Plus one for checking toe in.
Postby Duck! » Sun Oct 21, 2018 10:10 pm
Plus another for toe adjustment. Just to clarify, you want the front end of the pads just slightly closer to the rim than the trailing end so they form a V, with the rotating rim entering from the open end.
DavidS
Postby DavidS » Mon Oct 22, 2018 8:05 pm
Mine shriek too on a roadie with V brakes and I have the pads toed in. Sometimes it just seems to happen. Pain though.
DS
AUbicycles
Site Admin
Site Admin
Postby AUbicycles » Tue Oct 23, 2018 3:55 am
A roadie with V-brakes? Like an older CX bike?
Again toe-in. The only tools are an Allen Key and patience..
Neddysmith
Postby Neddysmith » Tue Oct 23, 2018 8:58 am
My brakes are great and dont have any problems braking in general, however, i have found they shriek when heavy braking after longer descents, so for mine it seems one the rim has heated, cant seem to get it happening when braking hard on the flat.
Trevtassie
Postby Trevtassie » Tue Oct 23, 2018 10:08 am
My secret for setting toe in is to use a loose zip tie of appropriate thickness around the end of the pad. With post mounts I put identical pieces of stiff plastic hose on the posts (between the pad and the locking bolt) so you don't need to be an octopus to adjust them. Post mounts were invented by a moron I think...
Loose the nuts, squeeze the brakes, tighten the nuts then take off the zip ties. That way you can be scientific with controlled gaps, still squealing, use a thicker zip tie.
RobertL
Postby RobertL » Tue Oct 23, 2018 10:14 am
Trevtassie wrote:My secret for setting toe in is to use a loose zip tie of appropriate thickness around the end of the pad. With post mounts I put identical pieces of stiff plastic hose on the posts (between the pad and the locking bolt) so you don't need to be an octopus to adjust them. Post mounts were invented by a moron I think...
I use a folded up piece of card - whatever I have lying around that's about the right thickness. Same principle, though.
DavidS
Postby DavidS » Tue Oct 23, 2018 9:10 pm
AUbicycles wrote:A roadie with V-brakes? Like an older CX bike?
Maybe more of a touring bike, Allegro T1.
Yeah, have toed in a fair bit, very fiddly on V Brakes.
DS
Mububban
Postby Mububban » Wed Oct 24, 2018 11:42 pm
Thanks for the info everyone. I've cleaned the rim (although the bike is brand new out of the box) - no change. Tried toeing in the pads using layers of cardboard - no luck. One pad seems to toe in well, but the other wants to stay flat, and shrieking up and down the street at 8pm isn't very neighbourly so I'll try again tomorrow.
Next step will be to try roughing up the pad surface. Failing that, take it into the LBS when I pick up my bike from service on Friday :)
Neddysmith
Postby Neddysmith » Thu Oct 25, 2018 9:08 am
One other thing you could try is just changing the brake pads, on the boys bmx i had a similar issue, cleaned brake pads and rims, adjusted toe in, roughed pads, etc etc etc nothing would stop it, changed front ad rear brake pads still the same, then bought new pads different compound and has been great ever since.
Thoglette
Postby Thoglette » Thu Oct 25, 2018 10:16 am
Mububban wrote:but the other wants to stay flat
Some brute force is called for to either bend or reshape the brake arm
P!N20
Postby P!N20 » Thu Oct 25, 2018 10:32 am
Disc brakes are the only sensible solution here.
</sarcasm>
Users browsing this forum: thamete, Thoglette
