Cracked DT Swiss Rim
silentC
Postby silentC » Tue Oct 30, 2018 9:46 am
DT Swiss R24 DB rear wheel.
Noticed I had a buckled rim on the weekend. On closer inspection, there are cracks radiating from a spoke hole and the metal is bent outwards as though the spoke head is being pulled through. The rims are only 3 years old.
I had a buckle in one wheel about two years ago after hitting a pothole and I got the bike shop to straighten it for me, but I can't remember whether it was this wheel or the front. Is this something you might see if you over-tighten a spoke to correct a buckle?
I guess there's no way of repairing it?
"If your next bike does not have disc brakes, the bike after that certainly will"
- Me
Re: Cracked DT Swiss Rim
Postby Duck! » Tue Oct 30, 2018 10:49 am
It's dead, and a symptom of excessive tension.
silentC
Postby silentC » Tue Oct 30, 2018 10:51 am
OK that's what I thought. Looks like new wheels for me then. Every cloud has a silver lining :)
- Me
Velo13
Postby Velo13 » Thu Nov 08, 2018 8:13 am
I suspect your LBS put too much tension into that one spoke to perform the original "repair".
3 years out of a factory wheelset is probably above average though ... assuming reasonable levels of usage.
