Track gearing ratio's for my age group
Where speeds may exceed 60 kmph
Postby Chaderotti » Sun Nov 08, 2009 3:46 pm
Anyone here have an idea what the track ratio's are for different age groups? I might start racing on the track and by that time I'd be 16. I had a shot on a track bike with the ratio for my current age group and it was far too easy.
Princess
Mistress = Pinarello Opera, Ultegra SL
Mistress #2 = Drag Bluebird
Chaderotti
by BNA » Sun Nov 08, 2009 4:49 pm
Re: Track gearing ratio's for my age group
Postby othy » Sun Nov 08, 2009 4:49 pm
othy
Postby stubbie » Sun Nov 08, 2009 5:18 pm
A young fit bloke like you? An 84/11 would be about right. :mrgreen: :mrgreen: :mrgreen:
Gravity will never let you down.
stubbie
Postby Chaderotti » Sun Nov 08, 2009 5:22 pm
Wow that's not really helpful.... 'roll out'. I thought the gear ratio would be more conventional.
6.5 metres. At 120 rpm my speed will be roughly 46.8 km/h. Gosh not fast enough :roll:
Princess
Chaderotti
Postby JV911 » Mon Nov 09, 2009 7:45 am
Chaderotti wrote:At 120 rpm my speed will be roughly 46.8 km/h. Gosh not fast enough :roll:
pedal faster!
everyone in your age group will be in the same boat so its not as if you're being disadvantaged
<---LACC--->
<---BMC SLR01--->
JV911
Postby Alex Simmons/RST » Mon Nov 09, 2009 10:30 am
Chaderotti wrote:Wow that's not really helpful.... 'roll out'. I thought the gear ratio would be more conventional.
Since gearing is also affected by wheels/tyres choice, then roll out is used to ensure a real gear ratio limit applies.
A little basic maths can help you.
Gear rollout = wheel circumference in metres * chainring / cog
e.g. a 49x16 on 2096mm tyres = 6.419 metres.
But always a good idea to check it by doing a rollout.
Alex Simmons/RST
Postby Chaderotti » Mon Nov 09, 2009 6:16 pm
pedal faster!
I'm more of a low rpm sort of guy. Lay down the power but spinning fast is where I have problems.
When the time comes around to getting a track bike I'll have a chit chat to my LBS.
Princess
Chaderotti
Return to Track
