Silly Q - name of tool?
Where speeds may exceed 60 kmph
Postby madrapper » Tue Mar 02, 2010 11:41 am
What are those single size wrench things used for removing the rear wheel of a track bike called?
Dave
madrapper
by Forum Ads » Tue Mar 02, 2010 11:53 am
Re: Silly Q - name of tool?
Postby ve safari » Tue Mar 02, 2010 11:53 am
Spanner.
For one to conquer oneself is the first and noblest of all victories!
ve safari
Postby foo on patrol » Tue Mar 02, 2010 3:17 pm
Ring spanner :wink:
Goal 6000km
foo on patrol
Postby bman81 » Tue Mar 02, 2010 4:00 pm
I use a pedal wrench for dealing with wheel nuts, but an allen key for my pedals. Go figure!
bman81
Postby Lark2004 » Tue Mar 02, 2010 4:23 pm
foo on patrol wrote:Ring spanner :wink:
15mm Ring Spanner... You need to be specific foo :P
Lark2004
Postby foo on patrol » Tue Mar 02, 2010 7:33 pm
Sorry, he didn't specify how old they were. :oops: :lol:
Goal 6000km
foo on patrol
Postby madrapper » Tue Mar 02, 2010 10:11 pm
Is it still a ring spanner if its got a socket like thing on the end of it? I think they are like this so u don't damage the dropout which is recessed on most track bikes I've seen.
Dave
madrapper
Postby pwbike » Wed Mar 03, 2010 7:00 am
A ring spanner has a closed (ring shaped) end with a single or double hex inside.
A flat spanner (also called open ended spanner) has a U shaped end with opposing flat sides.
A combination spanner has a ring at one end and an open end at the other (both of same size).
pwbike
Postby madrapper » Wed Mar 03, 2010 10:22 am
Hmmm... a normal spanner, ring spanner or shifter wont do the job. I might have to wait till I get out to the track again and ask there.
Dave
madrapper
Postby brentono » Wed Mar 03, 2010 11:07 am
madrapper wrote:Is it still a ring spanner if its got a socket like thing on the end of it? I think they are like this so u don't damage the dropout which is recessed on most track bikes I've seen.
Spot-on, you got it. :idea:
BrentonO
Lone Rider- I rode on the long, dark road... before I danced under the lights.
brentono
Postby dodgiebros » Sun Mar 07, 2010 7:44 am
bman81 wrote:I use a pedal wrench for dealing with wheel nuts, but an allen key for my pedals. Go figure!
How's about 'Pedal' or 'Crank' wrench? :shock: :lol:
dodgiebros
Postby kukamunga » Sun Mar 07, 2010 8:11 am
A few wheel nuts are 17 mm across flats - the Apollo Salt and Pepper retro fixie/single speeds come inexplicably with these :?
Just Ride
kukamunga
Postby singlespeedscott » Thu Mar 11, 2010 7:06 pm
Miche uses 14mm. :roll:
Postby Lark2004 » Fri Mar 12, 2010 6:14 am
or
then your set no matter what size nuts your bike uses.....
and for the people with the flashy front axles that don't use nuts....
Lark2004
Postby toolonglegs » Fri Mar 12, 2010 6:59 am
Ring spanner,open ended spanner,open ended adjustable spanner,open ended / ring combination spanner ...list goes on for a while.Just call it a tool.
"Mate,can I borrow a tool to take my wheel out"
"No,go buy your own"
Funny thread.
Return to Track
