Where speeds may exceed 60 kmph
by orbeas » Fri Dec 10, 2010 6:16 pm
tripstobaltimore wrote:orbeas wrote:should tubs be glued on without rim tape?? as iv remouved the tyre and there is no rim tape.. thx  no rim tape!!!
phew thanks!! A note for other tubular users that may be use full; iv been using some flat proof stuff in the tubs for over a year Summers here i went to pump the tubs up and air is excaping from arround the side walls, (lucky i bought 2 tubs last year for spares). IS This a coincident or have others found leaving flat proof goo in the tubulars damaging to the tubes? thx
Orbea Euskaltel:Ultegra,Durace,RS80 Orbea Erandio Hybrid
orbeas
by BNA » Fri Dec 10, 2010 7:30 pm
by foo on patrol » Fri Dec 10, 2010 7:30 pm
Aaah no, you don't use rim tape when glueing.
I don't suffer fools easily and so long as you have done your best,you should have no regrets. Goal 6000km
foo on patrol
by Chaderotti » Fri Dec 10, 2010 9:27 pm
Gluing tubs to rim tape? Amazing! Let's say it adds 4 seconds in a 40 km TT and make millions.
Princess Mistress = Pinarello Opera, Ultegra SL Mistress #2 = Drag Bluebird
Chaderotti
by Chaderotti » Wed Jan 05, 2011 4:07 pm
There are so many conflicting opinions. Some say tape is better than glue, others say it's suicidal. Glue takes about 6 months to install Tape takes about 6 minutes.
Chaderotti
by foo on patrol » Wed Jan 05, 2011 5:13 pm
Don't use tape on the track!!
foo on patrol
by Chaderotti » Thu Jan 06, 2011 2:00 am
Bugga, ordered tape anyway.
Chaderotti
by brentono » Thu Jan 06, 2011 10:05 am
Chaderotti wrote:Glue takes about 6 months to install (who tells you this sh*te! forum wannabees?)  Alert! Right on Foo. +1 shellac for track
... end of story.
Lone Rider- I rode on the long, dark road... before I danced under the lights.
brentono
by alex » Thu Jan 06, 2011 3:40 pm
you will never roll a tyre with normal glue if it is glued correctly
tyres : vittoria evo pista glue : conti
you can use shellac if you want, but i dont see any real world reason to do that
if i get killed while out on my bike i dont want a 'memorial ride' by random punters i have never met.
alex
by brentono » Thu Jan 06, 2011 5:10 pm
alex wrote:but i dont see any real world reason to do that Cost (shellac, will do exactly what glue will do, if not better-historically) If it's going to be glue, Chad, do it properly. http://www.engr.ku.edu/~kuktl/bicycle/Cusa1.pdf
brentono
by foo on patrol » Thu Jan 06, 2011 5:54 pm
Chaderotti wrote:Bugga, ordered tape anyway.
Give yourself an upper cut Chad and then slap yourself around a bit, so you don't forget! Foo
foo on patrol
by alex » Thu Jan 06, 2011 10:06 pm
a 14 page doc on gluing tyres? wow.
the best advice is to keep it simple.
everyone else uses normal glue because it works fine and is easy to source and use.
the only people using shellac are the old skool blokes in their 70s - and probably only because they have been doing it for years and can't be bothered cleaning all the shellac off their rims to use normal glue. at your local track 99.9% of people will be using normal conti or vittoria glue.
go to your local track and you will find that nobody is rolling tyres there, with glue or shellac. it is very rare and they mostly only happen halfway through a crash when you are already sliding on the boards (have a look on youtube). you really need to put some incredible lateral forces on the tyre to get it to roll, like turning your front wheel sideways at 70 km/h.
alex
by brentono » Fri Jan 07, 2011 11:12 am
alex wrote:go to your local track and you will find that nobody is rolling tyres there, with glue or shellac.
You said it. (that's my point  )  incredible lateral forces
Don't mention that here, you'll start a huge debate.
brentono
by toppity » Fri Jan 07, 2011 12:11 pm
brentono wrote:alex wrote:go to your local track and you will find that nobody is rolling tyres there, with glue or shellac.
the engineers are always lurking
toppity
by ironhanglider » Sat Jan 08, 2011 10:55 pm
toppity wrote:brentono wrote:alex wrote:go to your local track and you will find that nobody is rolling tyres there, with glue or shellac.
Even non-engineers lurk... However any engineer worth his salt will tell you that there is a performance difference between shellac and glue. This is due to hysteresis losses in a soft glue, that are not present in a hard adhesive such as shellac. This is measurable and is the reason why tubular tyres performed unusually badly in rolling resistance tests done on a steel drum http://sheldonbrown.com/brandt/rolling-resistance-tubular.html. The question would be whether you are running tubulars for convenience or performance. There is no doubt that a road tyre and road glue will perform quite adequately and safely and this is demonstrated every week by others doing just this on the track. I wouldn't be surprised if people are using tape either. If you want to squeeze every last drop of performance from your bike then you should be using track tyres and shellac. I agonised over this when I was building my wheels and eventually went for clinchers - for convenience, but I mainly ride on outdoor tracks where punctures are more common. (and because I can fix a flat between races without having to borrow a wheel) I went with clinchers principally because with good tyres and latex tubes the performance difference is orders of magnitude less than what can be achieved by hardening up the nut that holds the bars. Cheers, Cameron Mechanical performance can be bought, physical performance has to be earned.
ironhanglider
by alex » Tue Jan 11, 2011 9:20 am
and anyone who is not losing olympic level races by one thousandth of a second will tell you just to use normal glue like everyone else
alex
by brentono » Tue Jan 11, 2011 11:35 am
alex wrote:and anyone who is not losing olympic level races by one thousandth of a second will tell you just to use normal glue like everyone else
losing olympic level races by one thousandth of a second = Sniff it!
brentono
by brentono » Wed Jan 12, 2011 11:34 am
Cameron, "Mechanical performance can be bought, physical performance has to be earned." So true, the clothes, the super light equipment, the right glue... doesn't maketh the champion cyclist. Reminds me of a funny line... "In that old Baudrillardian challenge, if one stages a bank robbery and carries the performance all the way to the bank, fooling even the teller and guards, one arguably has succeeded in redefining oneself not as an actor, but as a bank robber."
brentono
Return to Track
