Hi Everyone,
I recently bought a track frame from a guy in Sydney (second hand). He had no idea where it came from or who had made it. The serial number has been removed from the bottom bracket, but it's obvious that there was once a number there. There is also a symbol/ numeral which appears as follows: 'S|3' , located on the post of the forks which I am going to assume is a manufacturing stamp of some kind.
The frame is the lightest one I've bought so far, and when compared with some other steel frames I have lying about it appears to be a thinner gauge tubing (please excuse my simple references- I'm a newcomer to home DIY bike maintenance and building)
The parts still left on the bike are all Tange (headset and bottom bracket). And the headset locknut has the word "levin" in italics on its surface. The bottom bracket is made in japan.
I've had a cruise through some blogs and websites and the only similar post I could find mentioned Nishiki as a possible manufacturer?
The lugs are pretty fancy, which is one of the reason I bought it. And they seem to match the forks. I'd like to do a really nice job on painting this frame if it turns out to be something worthwhile and restore this into a nice fixed gear bike as a little project on the weekend. Something tells me this frame is a piece of commercial junk however, but you never know..
If anyone has any idea where I could look or knows or has seen these lugs before I'd appreciate a post! Thanks for taking a minute to read through!
The link below will take you to a few pics I took and posted to flickr.
http://www.flickr.com/photos/64159235@N ... 980711466/
Lachlan
