Track Tyres 20mm or 23mm
Where speeds may exceed 60 kmph
Postby mikesbytes » Fri Feb 15, 2008 10:42 am
I've got stuff on ebay
mikesbytes
by BNA » Fri Feb 15, 2008 11:03 am
Re: Track Tyres 20mm or 23mm
Postby singletracking » Fri Feb 15, 2008 11:03 am
When rolling resistance is more important than compliance?
In application - an indoor timber velodrome with a super-smooth surface allows you to run a skinnier, harder tyre that would be too much of a handfull on a rougher, bumpier outdoor track where you'd want the additional bag of a 23mm tyre.
Or you could go for singles... :wink:
singletracking
Postby mikesbytes » Fri Feb 15, 2008 12:06 pm
I'll be doing most of my training on a concrete track and most of my racing on a wooden track
mikesbytes
Postby Birdman » Fri Feb 15, 2008 12:58 pm
Two wheelsets...for both types....
Hell buy 7 sets one for each day of the week !!!
Mitch.
Until next time...
Birdman
Postby mikesbytes » Fri Feb 15, 2008 1:05 pm
I'm thinking 20mm on the front and 23mm on the rear.
Bloke I know runs 140psi on concrete and 160psi on wood. Don't think I'll go that hard myself.
mikesbytes
Postby tallywhacker » Fri Feb 15, 2008 3:36 pm
that high with clinchers on a track is not good, makes it easier to roll the bead off the rim as I found out first hand. At 100kg I was using 145psi, recommended that I drop that down to 130psi max. If you need to run higher pressures use tubulars.
tallywhacker
Postby 531db » Fri Feb 15, 2008 4:41 pm
20mm will be fine on both Dunc Gray II and Tempe.
23mm is what you might prefer on bumpier tracks such as Muswellbrook, Queanbeyan etc.
I use 20C Conti's on the Guerciotti at DG II, Illawarra and Goulburn.
531db
Postby mikesbytes » Fri Feb 15, 2008 6:38 pm
Thanks Guys,
I've never ran more than 130psi, can't see myself ever going to 160psi, not even at Dunc Gray.
What is the surface like at Lidcome ?
mikesbytes
Postby notdjp » Mon Dec 20, 2010 11:41 am
Is there any benefit to riding the wider tyre on the front? I ride on an outdoor track and just realised last night that the second-hand track bike I have has 21mm on the rear and 23mm on the front. :?
notdjp
Postby mikesbytes » Mon Dec 20, 2010 1:42 pm
This old thread has been dug out
Unlike my statement in 2008, I've been using 20mm on the front and 23mm on the rear. I use 140psi on concrete and 160psi on wood.
mikesbytes
Postby toppity » Mon Dec 20, 2010 2:20 pm
mikesbytes wrote:This old thread has been dug out
never say never :D
toppity
Postby notdjp » Tue Dec 21, 2010 12:24 pm
Any thoughts on riding the 23 at the front and the 20 on the rear?
notdjp
Postby mikesbytes » Tue Dec 21, 2010 2:51 pm
notdjp wrote:Any thoughts on riding the 23 at the front and the 20 on the rear?
20mm gives better aero on the front
mikesbytes
Postby notdjp » Wed Dec 22, 2010 11:03 am
Hmm. Thanks. Thought the 20 may have been put on the front for better control ...
Will swap them around to see if it makes any difference.
notdjp
Return to Track
