Tooth Thicknesses
Where speeds may exceed 60 kmph
Tooth Thicknesses
Postby JB » Tue Mar 06, 2012 1:55 pm
Track cogs seem to be available in either 3/32" or 1/8" tooth thicknesses. eg
http://www.wiggle.co.uk/miche-fixed-track-sprocket/
no idea what this means or what thickness I should buy.
I'm gearing up a new Avanti Pista 2012
http://www.avantibikes.com/track/2012-pista-bike.aspx?bid=436
Any help appreciated.
John
JB
by BNA » Tue Mar 06, 2012 2:15 pm
Re: Tooth Thicknesses
Postby JB » Tue Mar 06, 2012 2:15 pm
Traditionally before bikes had gears and multiple sprockets on the rear the standard for chains and sprockets was 1/8". When derailleurs with multiple sprocket cassettes started they had to make the sprockets thinner to fit them all in so they made them 3/32". Single speed track bikes still use 1/8" sprockets and chain and I checked the spec in the link you posted and your bike has a 1/8" chain so you will need a 1/8" sprocket. The reason you can buy 3/32" single sprockets is that people often want to use a chainwheel from a bike with gears to to create a single speed bike so they already have the narrower chainwheel but it is not a good idea because narrow chains are not as strong as the 1/8" chains used on track bikes
thanks for the reply above,
John
JB
Postby tripstobaltimore » Tue Mar 27, 2012 7:41 am
I might just add to that -
There's no issues with 3/32" strength, so don't worry about that.
With 1/8" you can use 3/32" cogs if necessary, but not vice versa.
In my experience, I've found finding 1/8" parts easier.
tripstobaltimore
Return to Track
