New Track Bike - Miche BB Question
variable
Postby variable » Fri Aug 23, 2013 4:40 pm
This is my first build and I went with a lot of Miche components. In order to install the Miche Primato BB are there any tools I need besides some loktite and grease?
Re: New Track Bike - Miche BB Question
Postby singlespeedscott » Fri Aug 23, 2013 7:08 pm
A Campagnolo lockring/bottom bracket splined tool.
dayne
Postby dayne » Thu Aug 29, 2013 8:41 am
I wouldnt be using loctite any where.
variable
Postby variable » Thu Aug 29, 2013 9:56 am
No? I've heard conflicting stories. One being that you'll never remove the bb should I use loctite, the other that the miche bb is loose. I guess I'll just install it without lotite and see if it's loose and deal with it then.
high_tea
Postby high_tea » Thu Aug 29, 2013 1:04 pm
FWIW I've used no loctite on my Miche BB and have had no dramas.
DavidI
Postby DavidI » Fri Aug 30, 2013 9:26 am
I'd use thread locker if the BB is Italian threaded, if it's BSA thread no need.
variable
Postby variable » Fri Oct 25, 2013 12:26 am
Does anyone know if the Miche Primato BB can be adjusted so as to have the chainring further off the frame?
