Individual and Team TT
by bradwoodbr » Thu Apr 09, 2009 3:59 pm
I would like some assistance in preparing my food for the Western Australian 160km TT. I have read that 30 to 60grams of carbs every 30 to 45 minutes is necessary, so I could use gels or honey. I can carry 1.5 litres of water and am going to use "Saltstick" capsules - about one very hour. Should I also be consuming some protein in liquid or solid form as well? If so how much? Any recommendations? Any advice would be greatly appreciated. Thanks
bradwoodbr
by BNA » Thu Apr 09, 2009 4:10 pm
by ni78ck » Thu Apr 09, 2009 4:10 pm
160km is a long distance, but i think if you eat well prior to the tt and have a gel every 45 minutes or so, with the odd banana you should be ok! if cramping is a problem for you, you will need some magnesium in you. you can take this in a drink bottle, or there are energy bars with magnesium in them. when you finish the race you can then gat the calorie count back to a normal level
Oppy Le Mauco - Dura Ace (wet weather bike) Cervelo S5 VWD - dura ace Di2
ni78ck
by Alex Simmons/RST » Sat Apr 11, 2009 4:15 pm
Depending on conditions, I would suggest you'll need more fluid. At least another litre. or 3 if it's hot. Perhaps there is a fluid replenishment station somewhere?
Alex Simmons/RST
by Ant. » Sat Apr 11, 2009 4:23 pm
The more I think of the 1 bidon holder on my P3, the more I want to sign up for the 40k option...
Cervélo R3 Cervélo P3C BT Blade
Ant.
by Alex Simmons/RST » Sat Apr 11, 2009 4:30 pm
Ant. wrote:The more I think of the 1 bidon holder on my P3, the more I want to sign up for the 40k option...
I'd suggest a bidon for a 40km TT is optional depending on conditions. Longer than an hour though and fluid is essential. Mind you, if it was a P4, well you want the bidon, just the fluid inside is optional Should TT riders pay more for medicare?
Alex Simmons/RST
by Ant. » Sat Apr 11, 2009 7:34 pm
Alex Simmons/RST wrote:Ant. wrote:The more I think of the 1 bidon holder on my P3, the more I want to sign up for the 40k option...
Definitely  Mentally unstable bunch of people
Ant.
by Ant. » Sun Apr 12, 2009 6:48 pm
I'd suggest a bidon for a 40km TT is optional depending on conditions. Should your athletes pay a greater medicare levy? But seriously, in TT style, isn't fluid practically mandatory for anything over, say, 30mins? Your answer here may explain why I pee 2mins before the start time and limit my cooldown to cycling immediately to the toilets.
Ant.
by Alex Simmons/RST » Sun Apr 12, 2009 9:05 pm
I didn't take a bidon on my last TT of > 40-min. Didn't need it. Bike I borrowed doesn't even have a cage I did on the one a month earlier, had a little sip at the turn but didn't really need it and wasted a few seconds in the process.
Alex Simmons/RST
by Troy C » Sun Apr 12, 2009 9:08 pm
I am doing the same TT, this also will be a first for me At the 80km tomorrow I will consumer 1.5lt of Endura and 3 gels (during the event) while planning to go under 2hrs then asses, how I felt after that, (Being easter, I have carbo loaded and no ridding today) I am Planning to go under 4.5 hrs for the 160 and intend use around 1lt of electrolyte and 2 gels per hr/lap so 4lt and 6-8 gels around the 160 I also have a mate that will be rolling to the swap of bottles, so non-stop 160 TA Troy
Rota-M Cycling Team, Board Member of ATTA, Member of CWA, WCMCC & PDCC
Troy C
by bradwoodbr » Mon Apr 20, 2009 1:44 am
Well done Troy, 4hours 10 minutes and 16 seconds - a very impressive average of 38.6km/hr
Thanks to everyone for their tips and hints about feeding. This went really well, however I think a better variety of solid food would help. Unfortunately my right ankle gave out on lap 3 and I had to retire.
I consumed the following in the three laps: 2 power bars 3 carb shots (1 before the start) 12 glucodin tablets (roughly 4 per lap) 1 banana (start of lap 3) 2 salstick capsules. One at the start and one at the beginning of lap 3. 1.5 litres of water for the first two laps. 1 litre in the third lap.
Congratulations to Mark Roberts for winning the event with an average of 39.2km/h.
Cheers Brad
bradwoodbr
by Troy C » Mon Apr 20, 2009 8:26 am
Cheers Brad, For the record I consumed 8 Carbo shotz, 1 before the start 1 powerbar 8 bottles of Endura Hard Ride
Regards Troy
Troy C
by nimm » Mon Apr 20, 2009 1:13 pm
Incredible, well done Troy. What was your avg heartrate?
/ Giant OCR / Go Vegan /
nimm
by Troy C » Mon Apr 20, 2009 7:49 pm
Jas, avg: 151, max: 166
Troy C
Return to Time Trial
