TT position
Individual and Team TT
Re: TT position
Postby toolonglegs » Thu Jan 28, 2010 9:38 pm
:lol: :lol: :lol:
by Forum Ads » Thu Jan 28, 2010 9:41 pm
Re: TT position
Postby Redbull » Thu Jan 28, 2010 9:41 pm
toolonglegs wrote:No it was his TT bike...they had to cut a hole in the head tube and mount the stem between the top and bottom bearings.
Holy Cow :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock:
Private Benjamin Bufford Blue's bottom lip would be a cow catcher on that thing.
The trouble with jogging is that the ice falls out of your glass
Redbull
Re: TT position
Postby Grant W » Fri Jan 29, 2010 8:04 am
Holy crap - that's low!
Boonen would like that bike, perfect position for sniffing the white lines.
LOL :mrgreen: :mrgreen:
Grant W
Re: TT position
Postby kosmiccarbon » Fri Jan 29, 2010 9:53 am
:lol: :lol: :lol:
:lol: haha that's gold
R2 Carbon Roadbike - 20 Speed Shimano 105
kosmiccarbon
Re: TT position
Postby philip » Fri Jan 29, 2010 10:09 am
mikesbytes wrote:Philip, is there anything you can inexpensively do to get your torso a little lower?
That's what I'm trying to figure out :) The only thing that I think is possible is a stem that puts the bars lower. But since the TT is only a week away I think I'll make do with what I've got for now.
philip
Re: TT position
Postby TheSkyMovesSideways » Fri Jan 29, 2010 10:36 am
I heard Prince had his 2 lowest ribs removed for that reason... :lol:
- Dave
TheSkyMovesSideways
Re: TT position
Postby DanielS » Fri Jan 29, 2010 11:02 am
philip - I wouldn't recommend trying out any super-aggresive low positions this far out from the race. Just go with what you've got.
One thing that I've found useful on my TT setup is to run the seat further forward and a little higher than it is in the 'road bike' position. The added height is to compensate for the steeper effective seat-tube angle when you put your seat forward. This positions your body over the bars more and opens up your hip angle, so you are not so squashed up. I'm not sure if this would be right for you, but its something you may like to consider.
Re. 2-up TTs - I've only done one of these before. We traded shorter turns, maybe 30 seconds tops.
This may seem obvious, but make sure the lead rider rolls backwards on the correct side. This is the side that the wind is coming from. E.g. if the wind is coming from the left, make sure the lead rider is rolling back on the left to protect the following rider as they come round. And obviously switch sides if there's a turnaround.
Make sure you both communicate with each other - if one rider is struggling they need to admit it! Keep the communication constant through the race!
Oh, and one thing we found doing the 2-up TT was that you can't flick an elbow to signal the following rider to come through when you are on aerobars. So we used a head-shake instead :)
DanielS
Re: TT position
Postby philip » Fri Jan 29, 2010 11:27 am
Thanks heaps for those suggestions Daniel. 30 seconds sounds very short, is there a reason for that or is it just what you felt comfortable doing? What distance was the one you did? We're doing the 50km Calga option, swapping every 30 seconds or so for over an hour is a lot of swapping!
philip
Re: TT position
Postby Christine Tham » Fri Jan 29, 2010 12:43 pm
Hi Phil,
I have made an attempt to Photoshop the image to correct for lens distortion, and perceived horizontal/vertical perspective distortion (using your wheels as a reference).
It's not a very professional effort, but should give an indication of how you actually look:
I don't know if that helps or not. You are better off taking a photo without perspective distortion, and then correct for lens distortion only to get a more accurate result.
Weekdays: "Bliss" (Trek Madone 5.2 2012) | Weekends: "Cadel" (self built) | Casual: "Kitty" (Giant Cypress LDS 2009)
Christine Tham
Re: TT position
Postby twizzle » Fri Jan 29, 2010 5:36 pm
He can't be competitive - he's missing my special aero-gut. :P
I ride, therefore I am.
twizzle
Re: TT position
Postby philip » Fri Jan 29, 2010 5:56 pm
twizzle wrote:He can't be competitive - he's missing my special aero-gut. :P
:P you might be onto something there - when I'm in a lower position my jersey flops about in front - I either need a gut or smaller jerseys!
philip
Re: TT position
Postby twizzle » Fri Jan 29, 2010 5:59 pm
I'd have baggy jerseys as well... but they don't often make a 4XL, so I just have to suck my gut in most of the time. Actually, it can't be too bad now, because when I'm low on the bike my thighs are hitting my rib cage rather than my stomach.
twizzle
Re: TT position
Postby othy » Fri Jan 29, 2010 6:00 pm
...skinsuit...
othy
Re: TT position
Postby DanielS » Sat Jan 30, 2010 12:13 pm
philip wrote:Thanks heaps for those suggestions Daniel. 30 seconds sounds very short, is there a reason for that or is it just what you felt comfortable doing? What distance was the one you did? We're doing the 50km Calga option, swapping every 30 seconds or so for over an hour is a lot of swapping!
Yeah there was no science behind it, but it felt about right. I think 30 seconds is enough time to recover in the slipstream, and as soon as the following rider is recovered, its best to trade off so that they are fresh at the front.
The only disadvantage to taking more turns is that the two of you as a 'unit' lose a bike length every time the lead rider pulls off. If the 50km TT takes you, say, 1:15 and you're trading off every 30 seconds, the total 'lost' distance is 150 bike lengths, or about 300m, or around half a minute. So not a huge amount compared with if you traded off every 2 minutes, where you would lose something like 5-10 seconds to trade offs. I think you will make up the difference in the added speed! (I hope that makes sense)
The 2-up TT we did was 44km, here in SA. It wasn't dead flat, there were some slight inclines/declines, and one fairly decent hill.
DanielS
Re: TT position
Postby Parrott » Wed Feb 03, 2010 8:30 am
Is that seat high enough, looks a little low in the photos going by the bend in your knee in the top shot, can't see your foot though. Apart from swapping the stem and rotaing the bars up a bit at the front doesn't look like you can do much more to get a good position on that bike :?: You seem pretty high at the front.
Parrott
Re: TT position
Postby philip » Sun Mar 07, 2010 1:14 pm
Well went and did the TT today at Calga - last month the weather was rubbish so we gave it a miss. 50km, 2 man. The course is by no means flat:
We did the 50km course so 2 laps of that. The guy I was riding with had done a 130km ride yesterday but he claimed he "rides better on tired legs" haha. This was my first TT and he hadn't done one up there before so it was a learning experience for both of us. We probably didn't push ourselves as hard as we could have, by the end of it I was still feeling pretty good so could have definitely gone harder. The results should be up soon but from memory we did 1:23:something and our 2nd lap was a minute or so faster than our first. He had a couple of mechanical problems which cost us maybe a minute. I did manage to get the bars a bit lower than I had in the pics in this thread so my position was ok. I didn't have any troubles with the position either which was good given that I had only spent about 20-30 minutes trying them out. We think if we pushed a bit harder we could probably have done a couple of minutes faster - we will have to go again next month to prove it :wink:
philip
Re: TT position
Postby toolonglegs » Sun Mar 07, 2010 4:34 pm
Nice Philip...is the two man TT a regular thing now?.
Re: TT position
Postby 1q2w3e4r » Sun Mar 07, 2010 5:18 pm
toolonglegs wrote:Nice Philip...is the two man TT a regular thing now?.
Seems to be, I've only been up there twice (last two months) and both times they had multiple two man TT's going.
1q2w3e4r
Re: TT position
Postby mikesbytes » Mon Mar 08, 2010 8:13 am
36.1kph ave. Not a bad at all, especially as yo didn't know the course
I've got stuff on ebay
mikesbytes
Re: TT position
Postby philip » Tue Mar 09, 2010 7:01 am
A bunch of the guys I ride with do a 2up as a bit of a friendly competition. From what I've heard at Calga you can make a team size of any number you like.
philip
Re: TT position
Postby Chris249 » Thu Mar 11, 2010 7:24 pm
Ant. wrote:ps.
This is me on my road bike...maybe you don't need clipon aerobars after all to look slippery!
Nice work!
Is that a dish back wheel, or a spoke cover?
I'm the acme of mediocrity at TTing (dead in the middle both times at Calga) and don't normally get sports gear to look cool, but I have to say I want a cover or disc back wheel just because they look drop dead stunning! :)
There are many types of racing cyclists. There is the sprinter, the rouleur, the stagiaire, the danser, the descender.... sadly, I'm a mediocre. :-(
2003 Cervelo P2K time trial bike
2010 Merida Cyclocross 4
2008 Giant SS/track
2008 Vivente Como roadie
Chris249
Re: TT position
Postby Richard.L » Thu Apr 01, 2010 7:25 pm
Ant's seat seem to be 5cm higher than his bars. Does this matter in TT's? or is that only a road race rule?
Richard.L
Re: TT position
Postby Parrott » Thu Apr 01, 2010 7:50 pm
Richard.L wrote:Ant's seat seem to be 5cm higher than his bars. Does this matter in TT's? or is that only a road race rule?
Don't know that rule. The front of the seat has to be at least 5cm behind the middle of the crank spindle if you drop a plumb bob off the nose of the saddle.
Parrott
Re: TT position
Postby Ant. » Fri Apr 02, 2010 11:17 pm
Chris249 wrote:
Ant. wrote:ps.
Nice work!
I missed this: it's a disc wheel, not a wheel cover. (you don't get the 'woosh woosh woosh' sounds with a wheel cover :twisted: )
Cervélo R3
Cervélo P3C
BT Blade
Ant.
Re: TT position
Postby Ant. » Fri Apr 02, 2010 11:24 pm
I run a 10cm saddle-bar drop on my road bike. No rule to do with that. As per Parrott, your saddle tip must be 5cm (or more) behind the bottom bracket (that photo there, saddle is about ~9cm behind I believe)
Cervélo R3
Cervélo P3C
BT Blade
Ant.
Return to Time Trial
