aero bar stack height; how low is too low?
Individual and Team TT
Postby Chaderotti » Sat Mar 27, 2010 2:54 pm
Got a fit up with a new cockpit, the guy set me up and dropped the bars down a couple of spacers. I'm just wondering how low is too low? I'm flexible enough to go lower but is there any drawbacks to going lower?
Princess
Mistress = Pinarello Opera, Ultegra SL
Mistress #2 = Drag Bluebird
Chaderotti
by Forum Ads » Sat Mar 27, 2010 6:49 pm
Re: aero bar stack height; how low is too low?
Postby Parrott » Sat Mar 27, 2010 6:49 pm
After a certain point you will begin to lose power as you go lower and may find some muscle groups tightening up. It is a trade off between power, aerodynamics and comfort which will be revealed by the stop watch. I progressively lowered my bars as I worked on my stretching, core strength and had spent more time training on the aero bars. It helps to have the seat right at the uci limit of 5cm behind the bottom bracket to keep the hip angle more open.
Parrott
Postby Alex Simmons/RST » Sun Mar 28, 2010 11:37 am
When:
1. it's no longer legal
2. it reduces your power to aero drag ratio (W/m^2)
3. it's unsafe
Alex Simmons/RST
Postby JV911 » Fri Apr 23, 2010 12:26 pm
Chaderotti wrote:how low is too low?
cadel says, "the lower the better!" :D
but for us mere mortals the limitations are: flexibility; comfort; safety; power generation etc
<---LACC--->
<---BMC SLR01--->
JV911
Postby Grant W » Fri Apr 23, 2010 9:05 pm
Well obviously, Cadel's bones and ligaments are made from rubber :D
Grant W
Return to Time Trial
