Best tyres for commuting?
Dai
Re: Best tyres for commuting?
Postby Dai » Fri Jul 01, 2011 6:29 pm
Just to deviate from the usual, I've been running 26" x 1.5" Geax Roadsters. I love these tyres, still going strong after three years and not a single puncture. Corners beautifully, long lasting, but still plenty of grip in the wet. If you're looking for some slicks for your MTB, these are highly recommended.
martinjs
Postby martinjs » Sun Jul 03, 2011 11:22 pm
Dai wrote:Just to deviate from the usual, I've been running 26" x 1.5" Geax Roadsters. I love these tyres, still going strong after three years and not a single puncture. Corners beautifully, long lasting, but still plenty of grip in the wet. If you're looking for some slicks for your MTB, these are highly recommended.
How many k's? That's the key for most of the riders who manage to knock a few. :D
Martin
Never underestimate the power of human stupidity!
Crawf
Postby Crawf » Tue Jul 12, 2011 8:54 am
I'm giving a big thumbs down to Specialized All Condition Armadillo's, within the first week this is what the front and back looked like, very odd given I ride the same route and have never had such an issue from any other tyre I've had. There hitting the bin after only 3000km.
Will be trying some Durano's, I would prefer to go back to Randonneur's but Wiggle dont seem to have them in the sizes I want anymore.
balap
Postby balap » Tue Jul 12, 2011 11:44 pm
I am a newbie. My bike has a GP4000 on the rear and Hutchinson Equinox on the front.
Equinox tyre has a smooth surface.
Can anyone tell me if it is a slippery tyre? I don't know to find that out myself.
Should I replace it with a different tyre for winter?
Postby il padrone » Tue Jul 12, 2011 11:53 pm
balap wrote:Equinox tyre has a smooth surface.
Your fears are a common cycling myth. It will only be a hazard if you plan on riding on mud or some types of loose gravel roads.
Sheldon wrote:Bicycle tyres for on-road use have no need of any sort of tread features; in fact, the best road tyres are perfectly smooth, with no tread at all!
balap
Postby balap » Wed Jul 13, 2011 8:47 pm
il padrone wrote:Your fears are a common cycling myth. It will only be a hazard if you plan on riding on mud or some types of loose gravel roads.
Very interesting reading!
Thanks for that.
Nobody
Postby Nobody » Wed Jul 13, 2011 10:02 pm
The opposite opinion:
Rivendell wrote:Tread
The best tread on dry asphalt is smooth. That's because the road bites into the tire, not the other way around, and the smoother the tread, the more contact the road makes, so the better your traction. On wet roads, we're not sure. Although smarter folks than we have said that bike tires don't hydroplane, it certainly seems to be the case that a slight tread helps a bit on a wet road. Nothing works on painted road lines.
http://www.rivbike.com/article/components/tires
You can never really compare the different types properly because the kind of tyres that come with some kind of tread are usually wider and designed to run at lower pressures. These lower pressure tyres give their own suspension which aids grip, all else being equal (which it usually isn't).
I'm not totally convinced in either direction and ride on tyres with and without tread. But if my life depended on getting through a corner as fast a possible in the wet, personally I would prefer to be on the fat squishy tyres, which usually come with some kind of tread (although as said, probably cosmetic only). That is why I have a wet bike with Schwalbe Big Apple (treaded) slicks in 2.35" (60mm). At 31/38psi not real fast, but comfortable and confidence inspiring on the road.
wolfrider
Postby wolfrider » Fri Jul 15, 2011 12:51 pm
Just put some Maxxis Re-Fuse, 700 x 23c tyres on.
LBS claimed them over their other tyres, so I'll give them a shot and keep you posted on wear, tear and punctures...hopefully lack of.
Mugglechops
Postby Mugglechops » Fri Jul 15, 2011 6:56 pm
Clocked up the first 200kms on my Marathon Cross tyres today. So far very impressed with them. A comfy ride and faster than my previous tyres.
Still look new too
martinjs
Postby martinjs » Thu Jul 21, 2011 11:51 am
martinjs wrote:Latest update on my 700 x 28C Schwalbe Marathon Plus both front and rear have just passed 7,001 km
Still no punctures, the front still looks as good as new and even the back still has tread pattern on it.
Remembering I'm no light weight and I'm usually riding with about 10kilo's of extra junk for work and cycling repair kit, not to mention the rough roads I ride on out here in the sticks. Best tires I've used to date. :D
Martin
Still going strong at 8,000k's as even the rear is showing tread still. :D Best tires for wear and puncture resistance I used to date.
Martin
DavidS
Postby DavidS » Sat Jul 23, 2011 2:32 am
Martin
Martin
Well I've only had the Marathons on for about 400KMs but they are proving good. They barely look worn, the Randeneurs looked worse after the same distance. Here's hoping I can get close to your 8,000KMs.
DS
fishwop
Postby fishwop » Sun Jul 31, 2011 10:20 pm
I would recommend Marathon Plus tyres for wear and puncture resistance as well, for those who commute on dodgy road surfaces.
Previous tyres were Vittoria Zaffiros that come standard on the Defy 3. Had 5 flats in as many weeks on those. I commute on the M4 motorway where there is horrendous amounts of crud (aka bogan droppings).
In 1600km on the Schwalbe's no punctures and they still look like new but they are harder to fit and seem to have a bit more drag about them.
scooter71
Postby scooter71 » Sun Jul 31, 2011 11:06 pm
preferably not flat..lol :wink:
martinjs
Postby martinjs » Wed Sep 14, 2011 8:07 pm
Martin
Martin
Latest update is my Schwalbe Marathon Plus both Front and Rear a passed 10,000k's. Front still looks really good and even the rear is still showing a small amount of tread. :shock: Best I've had by far. 8)
Martin
Mugglechops
Postby Mugglechops » Wed Sep 14, 2011 10:16 pm
Thats a lot of Kms. I don't think my Marathon Cross tyres will last that long. Coming up to 2000kms now and the rear looks about half worn.
Maybe my 120kgs is not real good for tyre wear :D
MattyK
Postby MattyK » Thu Sep 15, 2011 10:13 am
My Marathons have ~ 6000+ km on them, front looks normal, rear probably at half depth (would have to pull out the vernier to check)
martinjs
Postby martinjs » Thu Sep 15, 2011 4:26 pm
Mugglechops wrote:Thats a lot of Kms. I don't think my Marathon Cross tyres will last that long. Coming up to 2000kms now and the rear looks about half worn.
I'm probably close to 100k at the moment, slipped a bit in the last 6 months. :oops: and the bike usually carries about up to 10 kilos of junk. Lunch, spare clothes and repair tools.
Martin
Hamster
Postby Hamster » Fri Sep 16, 2011 9:05 pm
I'm using Continental Travels on the MTB I use for commuting. After 5,600 kms they are worn but not worn-out and have plenty of wear left. In that time I've had one puncture . I'm pleased with them and would recommend them.
It would not be at all strange if history came to the conclusion that the perfection of the bicycle was the greatest achievement of the nineteenth century.
Chef
Postby Chef » Fri Sep 16, 2011 9:34 pm
Hi,
I have been running 30mm marathon racers for a while now on my Pro-Cross; two punctures in about 7,000km (both punctures were in the sidewall and happened early on), and the rear probably has another 2,000 km left to go - if only I could get a chain that lasted as long!
As well as being fairly bomb proof they roll and corner well in most conditions; they certainly seem to keep beter traction in the wet than the marathon plus that I used to have.
http://www.chainreactioncycles.com/Models.aspx?ModelID=24795
Phil.
lethoso
Postby lethoso » Fri Sep 16, 2011 10:27 pm
Chef wrote:I have been running 30mm marathon racers for a while now on my Pro-Cross; two punctures in about 7,000km (both punctures were in the sidewall and happened early on), and the rear probably has another 2,000 km left to go - if only I could get a chain that lasted as long!
How do they roll compared to other marathons? My set are a long way from worn out (with 5000km on them) but when the time comes I'd like to replace them with something that rolls a little better, without giving up much puncture resistance.
With you on the chains - I've got 2000k on my most recent chain and it's running a bit sketchy already :?
Chef
Postby Chef » Fri Sep 16, 2011 10:44 pm
lethoso wrote:How do they roll compared to other marathons? My set are a long way from worn out (with 5000km on them) but when the time comes I'd like to replace them with something that rolls a little better, without giving up much puncture resistance.
I run Ultremo D tyres on my road bike - These are the best rolling tyres I have had. The marathon plus I used to have would be the worst in that regard. The racer is more like the plus than the the Ultremo, but still pretty good for a heavy duty tyre. The stand out for me is the the handling - I found the plus handled awfully - especially when leaning/cornering in the wet - the racer is much more confidence inspiring.
notwal
Postby notwal » Sat Sep 17, 2011 10:02 am
Cruiserman wrote:Hutchinson intensive road tubeless with Stans notubes sealant.
+1
6600 km so far and more to go. Zero punctures that I'm aware of. Riding in all conditions but there hasn't been much rain lately.
700x25C. 330 g. Nice ride. Medium grip. Expensive
judged, insulted, gone
teamdanby
Postby teamdanby » Mon Sep 19, 2011 8:13 pm
GWH74 wrote:Hi
What some opinions on 26" tires for commuting / weekend cycling.
I have a a MTB that I only use on the road and bike paths around western Adelaide and both are fairly smooth.
Currently running Tioga City Slickers in 1.5". Not too bad of tire except I have had a few punches from small thorns / glass and the rear started to flatten out after 2000Ks, swapped with the front at the moment, still have plenty of life left in them both.They also have a max pressure of 60 PSI (I run them about 50)
Was think of changing to Continentals. Maybe the Sports Contact (1.3"), Ultra Gatorskins (1 1/8") or even GPs (1 1/8"). Leaning towards the Sports Contact due to the puncher protection.
But am a bit worried as these are all a near full slick and aren't the best in any sort of wet condition (not that I ride in the rain)
Other option was to change wheel sets to a 29er / 700c so I have a much larger selection of tires in 28, 32 widths. Then would go for something like a Vittoria Randoneur.
Wheel set I was looking at was something like http://www.cellbikes.com.au/Shimano-WH-T565-Mountain-Bike-WheelSet. Need to do a few measurements to check that they will fit my 26" frame / forks.
Any thoughts?
i use the city slickers also and they may not be the best out there but they are holding up well enoght for me so far
have had a bit of drama with glass and one puncture but as i work as a rubbish tip i think that is going to happin no matter what
even in the ute i managed to have two wheels have punctures
i run mine at 60psi and they do roll very well and feel great
that said i will change for the next set if i find another good semi slick that has a high psi rateing and a better puncture protection
but next thing on my list is to get another set of wheels set up for the MTB but with road gearing as some of the gaps in the MTB gears are massive
Daily comuter
Gaint XTC mtb
city slicker wheels for the week
kenda nevegal for the tracks on the weekends
queequeg
Postby queequeg » Wed Sep 21, 2011 4:42 pm
Martin
Martin
Martin
Ho wmuch has your rear tyre squared off? My Marathon Plus 700x28c rear tyre was starting to show the blue protection layer through it, and was well and truly sqaured off. The front tyre was fine (and is now my back tyre). I finally replaced it once the whole tyre was showing blue. I definitely got my $34 worth out of that tyre!
martinjs
Postby martinjs » Sun Nov 06, 2011 5:20 pm
Martin
The Marathon Plus tires are still going, passed 12,000k's on both front and rear. Thinking of replacing the back one's in the next month or so but the front may even get me through to 20,000k's.
Good tires and no punctures yet!
Martin
