Best tyres for commuting?
Re: Best tyres for commuting?
Postby jasonc » Wed Nov 26, 2014 4:50 pm
I retired my old tyres and wheelset on the weekend
now running:
pro-lite garda
schwalbe marathon 25c front
schwalbe marathon 25c plus rear
queequeg
Postby queequeg » Thu Nov 27, 2014 12:19 am
I run SMPs front & rear but have run a lighter tyre on the front (marathon supreme). Regardless of the tyre brand, the newest tyre goes on the front. When the rear wears out, move the front tyre to the rear and put the new one on the front.
If you use a different tyre on the rear, you'll be putting in a new rear tyre whilst still having an older one on the front. That may or may not be an issue.
warthog1
Postby warthog1 » Thu Nov 27, 2014 3:01 pm
I'm happy to run a lighter tyre on the front as I believe it more important grip wise and IME the front is far less prone to puncture and lasts ~3 x longer than the rear.
Durano plus on the front at the mo and randonneur on the rear.
caneye
Postby caneye » Fri Dec 05, 2014 10:43 am
anyone running Rubena Flash on their commuters?
gresford
Postby gresford » Fri Dec 05, 2014 11:14 am
Could this be the ultimate commuter tyre?
http://www.telegraph.co.uk/men/active/r ... tures.html
Postby jasonc » Fri Dec 05, 2014 11:37 am
gresford wrote:Could this be the ultimate commuter tyre?
old riding buddy tried it. terrible handling. don't last as long as suggested
warthog1
Postby warthog1 » Fri Dec 05, 2014 4:59 pm
caneye wrote:anyone running Rubena Flash on their commuters?
http://www.bicycles.net.au/2014/04/rubena_flash_stop_thorn_ultimate/
ItsDank
Postby ItsDank » Mon Jan 19, 2015 2:59 pm
This is the ultimate commuter tire.
Great grip in the wet, made out of kevlar, dual compound and water channels. Seen me through the worst Sydney weather no problems.
Postby singlespeedscott » Mon Jan 19, 2015 6:03 pm
ItsDank wrote:This is the ultimate commuter tire.
Doesn't look like a very commuting bike setup.
yugyug
Postby yugyug » Mon Jan 19, 2015 6:15 pm
Water channels is Marketting BS. bicycles don't hydroplane.
ItsDank
Postby ItsDank » Mon Jan 19, 2015 6:37 pm
No but they do slip under pressure. The channels grip onto the slightly bumpy tarmac.
kb
Postby kb » Mon Jan 19, 2015 11:14 pm
ItsDank wrote:
yugyug wrote:
ItsDank wrote:Great grip in the wet, made out of kevlar, dual compound and water channels. Seen me through the worst Sydney weather no problems.
I thought they were to direct spray to the side instead of in your face or up your back.
yugyug
Postby yugyug » Mon Jan 19, 2015 11:53 pm
If that was the case then they would not be water channels but just like regular tread. And it's well known that tread on bicycles is also marketing-based design, as opposed to functional design, for the same reason, except when the ground surface is softer than the tire and able to be displaced by the tire, as in mountain biking and cyclocross. On a road which is harder than the tire, all tread does is needlessly give up space for traction.
yugyug
Postby yugyug » Mon Jan 19, 2015 11:56 pm
kb wrote:
ItsDank wrote:
yugyug wrote:[quote="ItsDank"]
I thought they were to direct spray to the side instead of in your face or up your back.[/quote]
I haven't heard that before. I dunno, doesn't sound right, water spray flies off a tire pretty fast, I doubt a tread pattern could direct it in any consequential way.
Get a fender if that's an issue? ;)
kb
Postby kb » Tue Jan 20, 2015 12:00 am
yugyug wrote:
kb wrote:Get a fender if that's an issue? ;)
My bike is a bit sensitive about her weight and I wouldn't want to "a fender" ;-)
Lukeyboy
Postby Lukeyboy » Tue Jan 20, 2015 2:33 am
yugyug wrote:I haven't heard that before. I dunno, doesn't sound right, water spray flies off a tire pretty fast, I doubt a tread pattern could direct it in any consequential way.
The tread pattern makes minimal difference on a bike wheel as they are so skinny and the tread blocks themselves aren't that big. There isn't enough surface area for it to be that noticeable compared to something like a car tyre where tread pattern does displace water differently.
yugyug wrote:Water channels is Marketting BS. bicycles don't hydroplane.
Not 100% correct. Yep. Bicycles don't aquaplane but in the rain when youre cornering traction is a different story.
skydance
Postby skydance » Tue Jan 20, 2015 2:57 pm
skydance wrote:opted for GP 4000S2. Let's see how it goes. Can't say for longevity, but that beast has fantastic grip even on wet (ish) roads.
Err... 2.100km now, wear indicators of the rear wheel are gone. It's not yet square, but not round as well. May take another 1-1.500 before puncture streak. Well, I did not expect it to live long.
Wonder if GP4000s2 (front) and Gatorskin (rear) makes any sense.
yugyug
Postby yugyug » Tue Jan 20, 2015 7:06 pm
Lukeyboy wrote:.
Ok so what's the story?
MattyK
Postby MattyK » Wed Jan 21, 2015 10:24 am
Tread pattern probably affects aerodynamics more than anything else.
Postby singlespeedscott » Thu Jan 22, 2015 5:53 pm
I don't think it would have any measurable effect at all. I would like to see a statistical analysis that would prove it so.
warthog1
Postby warthog1 » Thu Jan 22, 2015 11:25 pm
Postby singlespeedscott » Fri Jan 23, 2015 1:13 am
Only avalible in a 23mm. A bit undersized in this day and age.
warthog1
Postby warthog1 » Fri Jan 23, 2015 4:37 pm
I still like 23's on the roadie but I'd go bigger on the commuter (25's) I must admit.
I've got narrow rims btw.
Does seem strange they haven't got them bigger.
I run the old leather specials on the commuter anyway, makes the roadie feel like a rocket as they ride like crud. :lol:
MattyK
Postby MattyK » Wed Jan 28, 2015 3:43 pm
singlespeedscott wrote:I don't think it would have any measurable effect at all. I would like to see a statistical analysis that would prove it so.
Note I said "probably", but here's some wind tunnel tests on various tyres on the same wheel:
http://flocycling.blogspot.com.au/2013/ ... sults.html
My take on that chart is that the small amount of tread / surface roughness aids the airflow around the wheel. The slick (no tread) tyres tend to stall earlier.
Does it matter on a commuter? Not likely... I said "more effect", not "significant effect" :)
Postby singlespeedscott » Wed Jan 28, 2015 10:11 pm
Especially once you mount those wheels to a bike and cyclist on top
