Commuting bike with disc brakes and internal hub
• Page 1 of 1
Commuting bike with disc brakes and internal hubHi there,
Can anyone help me with pointing me towards any bikes that are sold with an internal hub, front disc brakes and come with the option of drop bars? i.e my dream commuting bike! Cheers, Damo Specialized S-Works Roubaix (With electronic Ultegra, oooo the boogey man)
Re: Commuting bike with disc brakes and internal hub
I'm not saying it doesn't exist, but if you wanna buy your dream bike, you might be better of building it yourself... The dutch have one word to describe the aussie MHL, this word is ;
SCHIJNVEILIGHEID !!
Re: Commuting bike with disc brakes and internal hubI'm building my own commuter at the moment.
It is going to have a disc on the front, drop bars, but derailleur gearing as I'm not sold on hub gears. Although the frame I'm using (Surly Cross Check) can be used for hub gears. From what I've seen so far, unless you are tall, you may be limited to cyclocross bikes. If you are tall, you could probably modify a single speed MTB with drop bars and hub gears*. *The reason for this is MTB frames (especially 29ers) have longer top tubes than road/'cross bikes.
Re: Commuting bike with disc brakes and internal hubGood find, but you forgot the most important bit: I think that is USD too. Very rich for a bike that is going to be ridden in the rain etc.
Maybe not exactly what you are looking for, but at least you could afford them: http://www.jamisbikes.com/usa/thebikes/ ... elite.html ![]() http://www.konaworld.com/bike.cfm?content=honkyinc ![]()
Re: Commuting bike with disc brakes and internal hubTough one, I think the Kona is about the only option.
Plenty of flat bar option though, Scott Sub 10, Merida Spresso and the bad boy to name a few...
Re: Commuting bike with disc brakes and internal hubMmmm, nice. I'll see if I can refinance the house and buy that.... The search continues, I'd really like drop bars just for battling into the Perth seabreeze on the way home! Specialized S-Works Roubaix (With electronic Ultegra, oooo the boogey man)
Re: Commuting bike with disc brakes and internal hubWhy are the internal hub and disc brakes so important to you? That bike you've commented on is the "dream bike" for you as specified in your original post. However, the price of any of these good internal hub bikes (ie with Rolhoff hub and disc brakes) is going to be similar to that one. You could do better (price-wise) if you opted for a conventional derailleur system. Riding in rain is not often a problem in Perth, so the derailleur system and conventional brakes are well suited to our climate.
Cheers, Graeme (Having said that, I did make sure I got discs for my recumbent bike so that I may swap them over for MTB wheels when touring. Nothing beats a 'bent into the Freo Doctor ... Think outside the double triangle.
--------------------------------------- My web site: www.scenebyhird.com --------------------------------------- The Bicycle Transportation Alliance
I'd like to stop riding my carbon bike with fairly aggressive geometry for my rides to work. With that, I'd like a bike that requires less maintenance, especially in winter (internal hub fits that bill) Disc brakes.. well that's an obvious one, I'd really like to try brakes that work in the wet
I'd going to have to try one of them one day, pretty sure I've seen you a few times riding up freeway south - Does look a lot easier during those gusty evenings home It's just a shame that my 'dream' commuter would cost USS$5100. I've seen a few sites that sell bar end shifters for the Shimano range of internal hubs, a good option seems to be converting any of the widely available commuters (Merida, Kona, Giant) to a drop bar. Specialized S-Works Roubaix (With electronic Ultegra, oooo the boogey man)
Re: Commuting bike with disc brakes and internal hubYou can do this (with STI style shifting no less!) with the combination of a Shimano Alfine 8-speed rear gearhub, and a set of Versa 8-speed integrated brake/shift levers. Alfine hubs have a Centerlock spline for a disc brake. For a disc brake caliper that works with the cable pull of road brakes, you can choose between the Avid BB5 and BB7 (Road versions), or Shimano R505.
If you aren't fussed about having integrated brake/shifting, you can get drop bar brake levers that are compatible with V-brake lever pull - in which case any MTB cable disc brake would work for you. Not quite sure how the shifter would fit then, you'd probably need the handlebar extension (mentioned below) similar to mounting the Rohloff shifter. For a frame to hang it all on, you could use a disc-capable 700c hybrid frame with a chain tensioner. Or if you want to be fancy and have a very clean looking setup, try and find a frame with an EBB or sliding dropouts so you don't need a tensioner. Such frames do exist; outside of going custom, Kona made some a few years back.. older Kona Sutras, and the Kona Exponent frameset ring a bell. You can also do it with a Rohloff, just the twist shifter at the end of the drop bar (there are little extensions available so it can be mounted there); and of course the hub is a lot more expensive. There is a company in the US (Dynamic Bicycles) that puts the Alfine-integrated shifter drivetrain together, but they don't equip it with disc brakes. link to Versa 8-speed shifter: http://www.sussex.com.tw/versa.html you can buy these at a few bike store websites. Peter
Steel may be real, but even both sides of the Cold War agreed titanium is better
Re: Commuting bike with disc brakes and internal hubI don't understand exactly why you would want disc brakes, when a good set of V-brakes and quality brake pads will do a similar job for much cheaper (and less maintenance). You can get an after-market STI lever or a bar-con shifter for Shimano Nexus-8 hubs. I'm eagerly awaiting Shimano's new 11-speed hub.
Martin Christopher Hartley
http://raleightwenty.webs.com - the top web resource for the Raleigh Twenty http://madmartysblog.blogspot.com - my cycling adventures
Re: Commuting bike with disc brakes and internal hubHow much cheaper are good V-brakes than say, Avid BB7's?
--Current rides: Cannondale Bad Boy 8 || Surly Big Dummy
Re: Commuting bike with disc brakes and internal hubAbout a third of the price. http://www.chainreactioncycles.com/Mode ... elID=31347 http://www.chainreactioncycles.com/Mode ... elID=22385
Hey Martin, what do you mean by "bar-con"? Do you mean like what's on that exy CoMotion bike above?
Re: Commuting bike with disc brakes and internal hubBar end shifters. They are mounted on the bar end of drop bars and have a lever you move up and down.
Re: Commuting bike with disc brakes and internal hubCannondale comes to mind..
Bad Boy 8 ![]() Also, maybe not the best for commuting... But I am in love with the Charge Mixer ![]()
![]() It's hard to see because it's the same colour as the bar-tape. ![]() This is the Barcon (Bar-Control or Bar-End Shifter) on it's own. Martin Christopher Hartley
• Page 1 of 1
Who is onlineUsers browsing this forum: jools |
