I have a question for other cyclists in Melbourne who use the Parkiteer cages. I've posted this question on the BV forums as well, however I was hoping for a more balanced view from here.
I've been a semi-regular user of the Parkiteer cage in Glen Waverley since it opened. Something that the cage is lacking (and since I haven't used any other cages, I can't compare) is a door handle on the outside of the door.
It means sticking your fingers through holes only slightly bigger than my fingers to pull the door open. I recall calling the Parkiteer number about it when I first started using the cage, but nothing happened. This morning I managed to get my finger caught and will have that great black fingernail look happening.
I called again this morning to see if there are any plans to put a handle on the door and the answer I was given was there was insufficient interest to do so.
Cable ties and other plastic based forms of handle have been tried and failed (broken/removed).
So my question to you gentle reader: Would the Parkiteer cages be improved by the addition of an external door handle, or should I add a spoonful of concrete to my breakie?
