Getting in to Parramatta from the end of the M7 cycle path.
Postby Nitram » Mon Sep 05, 2011 12:32 pm
I know there's a thread for commuting routes, but ................ here goes anyway.
I regularly come in from the Blue Mountains to Parra via the M4 and to the hole-in-the-wall just short of Church St, and then fiddle about through the back streets to the GWH and etc etc to parra CBD. But today I tried jumping off the M4 at the M7 interchange and riding around the fabulous cycle path through to where it ends at Old Windsor Rd. :D :D
The bit from there down to Briens Rd via more cycle path and the T-Way (is it OK to ride on the T-Way ? There was a bloke up ahead on a bike....... :oops: ....) was Ok, but I turned Left there and it was all shite from there on in. :( :(
So is there a decent way to get from Brien's down to the Parra CBD or is it just footpaths, pedestrians and traffic lights ?
Ta,
Nitram
Nitram
by BNA » Tue Sep 06, 2011 10:30 am
Re: Getting in to Parramatta from the end of the M7 cycle pa
Postby Scouse » Tue Sep 06, 2011 10:30 am
You could cut through Westmead hospital & then onto Parramatta Park. Turn off Briens Rd / Cumberland Hwy at Redbank Rd (where McDonalds is) & then down into the hospital. There's boom gates to stop cars using it as a shortcut but they're easy to go around on a bicycle.
Scott
1975 Peugeot UO-8 - daily commuter along the Liverpool to Parramatta cycleway (and back again :))
**Now living south of Campbelltown so commuting with the help of Mr Cityrail.
Scouse
Postby Xplora » Tue Sep 06, 2011 2:05 pm
When do you go through Nitram? I could take you along the path into Parra Park if the schedules match up. PM me your mobile if you're keen.
Xplora
Postby Nitram » Tue Sep 06, 2011 8:08 pm
Hi Scouse and thanks for your offer Xplora.
I tried my luck with it again today and found my problem: At some stage (I think its up the top of the hill from Briens Rd) there's a sign saying turn left for Parra. But that's a bum steer. If you turn right and head down to Briens Rd, turn right on Briens and then left on the bike path that runs alongside Mons Rd T Way, then follow the signs to Parra and through Parra Park its all good. A bit of a fiddly route-a bit stop-start. But after coming down from Springwood, I'm due for a bit of a rest !
Thanks again, and I think I'll use that route regularly, when not in a hurry.
Nitram :D
Nitram
Postby ruscook » Tue Sep 06, 2011 8:24 pm
GT Avalanche 1.0 | TCR Alliance 0 | Giant Bowery | BMW K1300R
Two wheels good, Four wheels bad
ruscook
Return to Commuting
