DRAFTING
Re: DRAFTING
Postby nescius » Thu Aug 16, 2012 1:24 pm
wurtulla wabbit wrote:Must be daft , I don't get why you would be set with someone getting an easier time by riding behind you.
You were doing what you were doing anyway ?
No change of plan so what are they getting off you for free that you could charge for or ask permission for ?
Cyclists and the politics are just silly at times.
The problem is that you don't know how competent they are, all it takes is a touch of wheels and you could both be thrown into traffic. My girlfriend had a wheel sucker run up the back of her when she slowed for a pedestrian on a crossing, luckily there was no damage to her or the bike, but it could easily have ended badly for both of them.
Giant Reign 3 | Trek 8000 | Trek Madone 4.5 | Look 695 SR ipack | Fuji Track 1.1
nescius
by Forum Ads » Thu Aug 16, 2012 1:28 pm
Re: DRAFTING
Postby wurtulla wabbit » Thu Aug 16, 2012 1:28 pm
Should they be that close ? I thought drafting would be a metre back at least ?
Being too close is asking for bother if they don't know you're there.
wurtulla wabbit
Re: DRAFTING
Postby clackers » Thu Aug 16, 2012 3:36 pm
The closer, the 'better', WW. 12 inches behind and three inches to the side of the wheel in front is one recommendation.
clackers
Re: DRAFTING
Postby wurtulla wabbit » Thu Aug 16, 2012 4:11 pm
That's a bit close for me:D, I'd stack it !
wurtulla wabbit
Re: DRAFTING
Postby bychosis » Thu Aug 16, 2012 4:27 pm
clackers wrote:The closer, the 'better', WW. 12 inches behind and three inches to the side of the wheel in front is one recommendation.
I guess that's for peletons and group rides with experienced riders using signals etc. but for day to day being half a length to a full length behind does stil give an advantage.
Re: DRAFTING
Postby clackers » Fri Aug 17, 2012 1:18 pm
Yep, but it's not as good, and you don't help the rider in front by filling up the air vortex behind him as well.
Triathlons actually define drafting as being within three bike lengths unless overtaking.
clackers
Re: DRAFTING
Postby bychosis » Fri Aug 17, 2012 1:58 pm
Maybe not as effective, but definitely safer when working with someone you don't know.
Re: DRAFTING
Postby clackers » Fri Aug 17, 2012 3:56 pm
And surely drafting is best as a consensual activity between adults! :)
clackers
Re: DRAFTING
Postby il padrone » Fri Aug 17, 2012 7:07 pm
One viewpoint on drafting
It is certainly the case that these guys are drafting a lot closer than 1 metre :shock: Less than 20cms is not uncommon for practiced riding mates. I've often ridden this close in headwinds on country road cycle tours - a couple of full panniers make for even more drafting power :wink:
Re: DRAFTING
Postby Red Rider » Wed Aug 22, 2012 10:24 pm
il padrone wrote:One viewpoint on drafting
That's all very well but doesn't help much with that annoying breed of urban cyclist who, having been overtaken on the open road then edge in front at a red light and/or set off before the signal changes.
If you're a light jumper, I reckon, then being drafted is the comeback.
That happened to me on Monday. Going thru the city this guy was going a bit slow so I took off to try and beat the lights. No dice, on three occasions I kept getting stopped by the lights, and each time he went in front of me at the lights. On the last occasion he jumped the lights, so after waiting for the lights to go green I chased him down and sat on his tale for the next 5km's :mrgreen:
Red Rider
Re: DRAFTING
Postby Thoglette » Sat Aug 25, 2012 5:54 pm
Kenzo wrote:When I pass a rider I expect they *will* be drafting me... and will check to see if they are on or not. Hopefully they stay long enough for a turn, if not then no probs either. It caused me no extra effort to have him/her/them on my tail.
Hear, hear. And etiquette be damned - if you are behind someone in commuting traffic it is your responsibility not to run up the arse of the person in front.
We can rant and rave all we like about what, when and how people should communicate on bikes but the sad reality is that you're lucky to get any indication of intent from other path users.
Thoglette
Previous
Return to Commuting
