lengh of commute
length of your commute each way
0-5ks
16
10%
6-10ks
49
31%
10-15ks
95
59%
Total votes : 160
Postby beauyboy » Thu Nov 16, 2006 4:16 pm
I am a competitive bugger i know that. But more so because he was on a roadie and i am on a hybrid. Yes Hybrids are fast but nothing like Roadies. That was proven on the day i did the ride as there was a road bike i was traveling near. On the hills i left him behind :D but on the decents he quickly caught up with me. :wink:
Donald
BCC give us some more bikeways fore safe travel!!!!
Upgrade the NCL now QR!!!!!!
http://nakedcyclistbrissy.blogspot.com/
My views do not represent any organisation I may be apart of unless otherwise stated
beauyboy
by BNA » Thu Nov 03, 2011 8:36 pm
Re: lengh of commute
Postby Porridgewog » Thu Nov 03, 2011 8:36 pm
Manage 21km each way normally six days a week rain or shine. Hills area in Sydney to Richmond. Get a few races now and then and met a good bunch of others training on the same route.....
Porridgewog
Postby cp123 » Fri Nov 04, 2011 8:15 am
your poll needs to go higher - i'm 18 or so each way.
cp123
Postby blossy84 » Fri Nov 04, 2011 8:35 am
My actual commute is about 8.5km each way, but I tend to mix it up a bit. Commuting to work I vary between usually a 15km ride and 20km ride, I've just added in a 27km ride to change it up again. On the way home I'll go one of two ways, one is about 10km and the other 12km.
i love my bike(s)
blossy84
Re:
Postby RetroPilot » Fri Nov 04, 2011 9:19 am
europa wrote:
sbra9635 wrote:I don't commute but I would really love to, but the main problem is I'd have to ride about 40km each way.... :(
Drive half way and ride the rest.
Ride in one day, bus home. Bus in the next and ride home.
I've known blokes who've done both.
yeah...ride with the wind if any on your back , train if its going to be in your face, either way. Taking the bike on train if necessary.
40km commute to work i would think, among other issues, is a bit testing for bike reliability especially tyres, sooner or later you will lose a tyre or its air at least, and whether you can fix it or not, will make you late.
also when applying for a job, never mention that you might be using a bike to come and go to it, a lot of bosses and probably HR people will see this as not being reliable or committed to reliability.
(they may also be hostile to cyclists generally, who knows)
Let them assume you are going to drive , then start showing up on the bike as if its your new fitness fad or something, once you are established.
Obviously none of this applies if its a public sector job. then you are probably encouraged to be a tofu-eating anarchist dedicated to a small carbon footprint, and as for your reliability, who cares in the public sector if u actually make it in or not.
RetroPilot
Re:
Postby London Boy » Fri Nov 04, 2011 5:19 pm
ShanDog wrote:I don't commute but I would really love to, but the main problem is I'd have to ride about 40km each way.... :(
Hills or flat?
If flat, 40k is easy. If hills, on the other hand, welcome to it... :)
London Boy
Postby Addictr3 » Fri Nov 04, 2011 6:58 pm
my communte is 45km each way, usually ride it 5 days a week.
If you can't explain it simply, then you don't understand it well enough.
Addictr3
Postby briztoon » Sat Nov 05, 2011 1:57 am
I walk to work. All 40 metres of it. I live accross the road from work. If it makes anyone feel better, I jump a fence and fight with some shrubbery most days.
briztoon
lengh of commute
Postby Amfos » Sat Nov 05, 2011 5:15 am
My commute is 23 km each way, do it 2-4 times a week, depending on weather and work commitments.
Amfos
Postby Euan » Sat Nov 05, 2011 9:18 am
I used to commute 30kms each way, flat so it only took about 70 minutes each way. My commute's 6-7 kms now, depending.
Distance isn't so much a factor so much as time, it would seem. Research in to this has been carried out in Sweden, it would seem that a commute of 45 minutes or more in one direction results in a 40% increase in divorce rates[1].
Yeah, I'm divorced :P
[1]Your Commute is Killing You
Euan
Postby roller » Sat Nov 05, 2011 12:50 pm
shortest route: 8.9kms
normal route: 19.9kms
long with hills: 35kms
long with flat: 40kms
it's nice to have so many options.
edit: if i take the bus(es) it's about 60-75 minutes.
roller
Postby jules21 » Sat Nov 05, 2011 1:07 pm
Addictr3 wrote:my communte is 45km each way, usually ride it 5 days a week.
cripes..
mine is about 8 km each way. but i try to lengthen it to 30 km on the way home. so usually 38 km or so both ways and if i get up early enough - 60 km.
i've convinved myself that riding an MTB on shared paths is harder work though - lots more braking and accelerating, rough surfaces, etc.
jules21
Postby Marto » Sat Nov 05, 2011 1:28 pm
My commute is 20 km in and 22 km home. It's longer going home as I avoid some slow/dodgy right turns and go on one stretch that is good for some interval training.
Marto
Postby Addictr3 » Sat Nov 05, 2011 7:19 pm
cripes..
Yeah I usually lengthen mine either morning runs, or riding home. I currently ride around 550km a week. People look at me like i have two heads, but riding to and from work has so many positives, it clears all the daily stress, and starts you off for a great day. Plus I sleep like a baby :-) good work though on your rides. MTB would be tough !!
Addictr3
Postby ldrcycles » Sat Nov 05, 2011 8:32 pm
Short commute (from gf's place)= 25k each way
Long Commute (from my place)=45k each way.
Try to do at least 2 days a week of either, best i've done was 5 of the long commute.
Postby trailgumby » Sat Nov 05, 2011 9:26 pm
Talk about the Zombie Apocalypse! :shock: :shock: :shock:
This thread has been dead for 5 years, and suddenly last Thusday it rises from teh grave in all its mouldy splendour!
Porridgewog, what have you done? :shock: :shock: :shock:
Postby ldrcycles » Sat Nov 05, 2011 9:29 pm
trailgumby wrote:Talk about the Zombie Apocalypse! :shock: :shock: :shock:
Holy Macaroni, i had no idea! How do people even find threads that old!
Postby DavidS » Sat Nov 05, 2011 11:06 pm
12KM in and 20KM home. I take the route along the beach on the way home. Unfortunately the prevailing SW wind is generally in my face every evening, on the beach that ain't fun.
DS
Riding: Cannondale Quick Speed 2
DavidS
Postby Marto » Sat Nov 05, 2011 11:25 pm
Marto
Postby ldrcycles » Sat Nov 05, 2011 11:33 pm
:lol: :lol: :lol:
Postby briztoon » Sun Nov 06, 2011 12:43 am
That's gold Marto. :lol:
briztoon
lengh of commute
Postby Amfos » Sun Nov 06, 2011 4:17 am
I'm impressed that your still here trail!!
Amfos
Postby Porridgewog » Wed Nov 09, 2011 8:37 pm
Sorry trail gumby. Didn't even see the date of last post.
Shall I take it as a bit of a trail blazing event for my 4th post!!!
Porridgewog
Postby cavebear2 » Thu Nov 10, 2011 12:02 am
I commute 5k's each way, that's why I have to go for training rides of up to 110 km after work..... and still get home at a time when the wife isn't too crabby!
cavebear2
Postby AndrewBurns » Thu Nov 10, 2011 7:37 am
22km each way, mix of relatively flat cycleways and a few big hills. I do it around twice a week now, depending on weather, in about an hour and 6 to 8 minutes each way.
AndrewBurns
Return to Commuting
cron
