Page 1 of 2
Radbot - 500 v 1000?
Posted: Mon Jun 24, 2013 10:35 am
by misterhorsey
Hello there.
Anyone have any experience of these lights?
I'm thinking of upgrading my rear light and was thinking of getting a 1000, but also concerned that it might be too bright. I'm commuting on roads and paths, and while I want to be seen I don't want to annoy or blind people behind me.
Is the 500 sufficient for visibility?
I was thinking one alternative is to buy 2x 500s. Mount one on the seat post and one on the rack. That way while I will have lights that are less bright, there will be two of them, which will build in some degree of redundancy should anything fail. Of course there's two sets of lights to take on or off and two sets of batteries to recharge, but that's not usually been too much of a hassle with my previous cateye rear light set up.
Partly interested in these lights due to decent reviews around the web as well as a discount voucher I need to use:
http://www.this link is broken/PDW-RADBOT- ... Best?ext=F" onclick="window.open(this.href);return false;
and the 500
http://www.this link is broken/PDW-Radbot-500-Rear-Light" onclick="window.open(this.href);return false;
Re: Radbot - 500 v 1000?
Posted: Mon Jun 24, 2013 11:13 am
by macca33
I have the 1000 - on all of my bikes - and it is fantastic. It is very bright and the batteries (2 x AAA) last a number of hours - cannot specifically recall the time, but well over 30 hours of riding when using the weird flasher mode.
Only thing I've noticed is that road grime / muck can get into the o-ring of the on/off button, so it has to be cleaned periodically to avoid it becoming stuck.
Posted: Mon Jun 24, 2013 11:14 am
by biker jk
I have used the Radbot 1000. It's very bright but the battery life is poor. I averaged around 7-9hrs between recharges. As such, I now have a Cygolite Hotshot which is just as bright, has more light patterns (and adjustability) and runs for at least 40 hours (USB rechargeable which the Radbot isn't).
Posted: Mon Jun 24, 2013 12:09 pm
by simonn
I've had three radbot 1000s for ~2-3 years. One died. It works until you hit a pothole then blinks dimly and feebly. If you take it apart and re-seat the batteries it works properly again... until the the next pothole. However, the problem appears to be with the circuitry, because if I swap around the part of the light with the battery holder the same problem occurs. Weird as!
Personally, I'd go one radbot and one fiberflare. Fiberflare is awesomely visible, very flexible as far as mounting goes and with ok battery life. Radbot is an adequate blinky with ok battery life, but also has a reflector which makes you legal (and audax compliant
The thing I do not like about the usb lights is that if the battery dies I cannot simply replace it with a spare set that I can carry (which is cheaper than carrying a whole spare light) or buy at the next servo etc. Depends on circumstances of course, but this is handy for audax at least.
Anway, go the 1000 over the 500. More light is better (up to a point, but 1W is nowhere near that point).
Posted: Mon Jun 24, 2013 12:24 pm
by DoogleDave
[quote="biker jk"]As such, I now have a Cygolite Hotshot which is just as bright....quote]
+1 for the Cygolite Hotshot. I have one and love it.
I always think it's going to run out mid-ride because it just keeps going but I am yet to have it run out of battery...and recharging is easy and painless.
Dave
Posted: Mon Jun 24, 2013 1:54 pm
by mikedufty
I bought the 500 thinking I was getting a 1000 (didn't realise there were two models). I've been perfectly happy with the 500, lasts several months of daily commuting on a set of batteries, is nice and bright, and comes with a reflector and rack mount. I have a second taillight of a different brand. I think two is a very good idea, especially as I find they tend to turn themselves off after 15 minutes when the batteries get flat, so you could find you've done half a ride with no taillight if you don't have two. Too important to depend on just one.
Posted: Mon Jun 24, 2013 2:52 pm
by misterhorsey
thanks guys.
i'm not sure if its misplaced, but I have a preference for stand alone rechargeable NiHM batteries. Cheap and easy to maintain if you have a little supply of them and a decent charger, as I do. Plus the radbot has a rack mount already with it, which is edging that one ahead for now over the Cygolite.
Unfortunately lights are consumables to an extent. We expect a lot from them but they also go through a lot. Relatively cheap tho.
(I know you can get a rackmount for another $10 or so for the cygolite but that's already half a radbot 500)
edit: spelling errors, typos etc
Posted: Mon Jun 24, 2013 4:29 pm
by TedDancin
I bought the Radbot 500 a few months ago, and due to some dodgy attachment on my part, lost it on a ride to work (metal bracket sheared off due to metal fatigue). Had the option of buying either the 500 or 1000 for the same price, and I bought the 500 again. I figure that the 500 is bright enough for me to be seen from behind, and the batteries last twice as long (reportedly ~75 hours on alkalines). Also have a much stronger bracket this time.
Posted: Mon Jun 24, 2013 8:25 pm
by Mulger bill
One of each, plus a redzone 4 on the commuter. They work and work well, no need to replace.
Simonn, check out the electrical connections between the two halves, a little oxydisation is not unknown.
Shaun
Posted: Tue Jun 25, 2013 10:29 am
by warthog1
My radbot 1000 has started playing up, only runs for a few minutes before switching itself off.
It is bright but battery life is poor and a PITA to pull apart and charge every 2 or 3 days. Get a USB rechargeable light. The cygolight sounds good.
Posted: Tue Jun 25, 2013 12:25 pm
by grasshopper
I have the 1000 and used to get about 25 hours out of non-rechargeables. But I would always run a secondary light with it, because when the batteries go it just dies; it doesn't fade. Not sure if the newer ones are different; this was one of the first batch. And +1 for the Fibre Flare for commuting too, although the first one didn't work and was replaced.
Posted: Tue Jun 25, 2013 2:49 pm
by misterhorsey
I went for the Radbot 1000 and will be running it with the cateye I have on at the moment. Radbot on pannier rack, cat eye on seat post.
Of course, I forgot what warthog1 and others said about battery life when I confirmed the order - doh! At least it will make me use the flat head screwdriver in the mini tool I bought as well. Woops, just checked that the mini tool doesn't have a flat head. doh x 2!
I'm intriuged by the fibre flare but I run pannier bags so my seat stays will be obsured. The reflectives on the back of the ortiliebs are very good from my experience, and combined with two relatively bright flashers I will at least be a cut above the median commuter in visibility me thinks.
Posted: Tue Jun 25, 2013 2:52 pm
by biker jk
misterhorsey wrote:I went for the Radbot 1000 and will be running it with the cateye I have on at the moment. Radbot on pannier rack, cat eye on seat post.
The Radbot requires a Philips head screwdriver to remove the batteries.
Posted: Tue Jun 25, 2013 3:10 pm
by misterhorsey
biker jk wrote:misterhorsey wrote:I went for the Radbot 1000 and will be running it with the cateye I have on at the moment. Radbot on pannier rack, cat eye on seat post.
awesome. I thought I read a review that it required a flat head. wonderful!
Posted: Tue Jun 25, 2013 5:48 pm
by LM324
It's very good for people (like me) who use a rack as they provide a mount for it. With most other brands you have to buy a mount, which is annoying when you pay $20 for a light and then you still have to pay another $10 to buy the rack mount.
Posted: Tue Jun 25, 2013 5:59 pm
by grasshopper
misterhorsey wrote:I'm intriuged by the fibre flare but I run pannier bags so my seat stays will be obsured. The reflectives on the back of the ortiliebs are very good from my experience, and combined with two relatively bright flashers I will at least be a cut above the median commuter in visibility me thinks.
Sounds good. I seem to get very good battery life from the Fibre Flare although I haven't tracked it. I just clip it across the top of the Ortliebs at night so I look a little wider on the commuter, but put it on the seat stay on the roadie.
Posted: Mon Jul 01, 2013 10:27 am
by misterhorsey
Bought and installed it, very happy with its operation so far.
I did a quick vox pop while waiting at the traffic lights, asked the motorist beside me and the cyclist behind me whether the light was too bright and they advised me that it was just fine. 100% approval from a sample size of 2.
Hopefully the construction will hold up and recharging won't be too annoying.
Posted: Thu Aug 08, 2013 10:31 am
by misterhorsey
So after 38 days of steady use, through many a rainy night, my radbot has started to die. Which is rather disappointing.
It will operate for about a minute before switching itself off.
The good news is that it ran for 38 nights of commuting on one set of batteries. Although these are not the longest commutes, and battery life isn't terribly important if the light doesn't work.
I've opened up and changed batteries, but will have another look to see if there are any battery seating issues.
Posted: Thu Aug 08, 2013 1:52 pm
by InTheWoods
Hmm they aren't very water proof. I often have to open mine up to dry out after it rains. Also check where the connectors from the battery side touch metal pads on the circuit/led side.
Posted: Thu Aug 08, 2013 2:14 pm
by Comedian
I've got four of them. A while back one started randomly switching off while riding.
Recently a second one has started doing the same. I find it very concerning when you finish a ride to find your light switched off at some point. Not good. In my experience once this starts happening it can't be fixed. I'm not sure what the cause is - but if they were designed to default to on after and break in power I don't think the problem would be as bad.
In fairness though... These were both high mileage lights so I don't feel too dudded.
So - I've switched to a moon comet. They need to be charged every few days. However they are tiny and light. Plus they have a stun the motorist mode plus a more sedate solid mode so you don't annoy your group riding buddies.
I believe cell have them for $35 at the moment.
Posted: Thu Aug 08, 2013 4:06 pm
by misterhorsey
My light still turns on, until the bike moves (or you simulate movement by shaking it), after which a contact point internally seems to skip a beat and then it goes dark.
On a side note, I bought this light online from cell. I rang their new fitzroy store to ask if I could drop by to discuss replacement/repair, and was advised that I could but it would be pointless as they are separate stores from online. I asked him if it was a franchise and he said that the name was franchised but not the store itself.
Rang cell who told me to send it back and they'll inspect and send me a new one. I asked if they would send me a different model, given the bad experience of the radbot, and they told me to write a note and they could discuss it (I'll pay the difference).
Hmmm. It was cheaper online but you get what you pays for, in terms of ease of return etc etc.
(edit)
Posted: Thu Aug 08, 2013 5:13 pm
by macca33
Still no problem with my Radbot 1000s (3 - on separate bikes) and average plenty of hours with them on burst mode - I'd say at least 30 hours (perhaps more and certainly over a month between changes) out of a set of batteries.
Posted: Thu Aug 08, 2013 5:26 pm
by biker jk
misterhorsey wrote:My light still turns on, until the bike moves (or you simulate movement by shaking it), after which a contact point internally seems to skip a beat and then it goes dark.
(edit)
Get the Cygolite Hotshot (Cell has it). It's excellent.
Posted: Thu Aug 08, 2013 6:07 pm
by rdp_au
The problem is almost certainly the contacts between the two sides of the casing. These are disturbed every time you open the light to replace the batteries. Give both sets of contacts a good clean with contact cleaner or fine emery paper and maybe tweak them up a little if it looks like they've lost their spring ... As others have noted, they are not particularly waterproof and shouldn't be mounted where they get direct spray off the wheel. Mine is mounted above a mudguard and seems to be doing ok. Non the less, I've recently upgraded to a Hotshot as well - brighter and with convenience of a built in USB chargeable battery
Posted: Fri Aug 09, 2013 6:36 am
by Comedian
rdp_au wrote:The problem is almost certainly the contacts between the two sides of the casing. These are disturbed every time you open the light to replace the batteries. Give both sets of contacts a good clean with contact cleaner or fine emery paper and maybe tweak them up a little if it looks like they've lost their spring ... As others have noted, they are not particularly waterproof and shouldn't be mounted where they get direct spray off the wheel. Mine is mounted above a mudguard and seems to be doing ok. Non the less, I've recently upgraded to a Hotshot as well - brighter and with convenience of a built in USB chargeable battery
I tried cleaning/tweaking the contacts etc. I agree this is the source of the problem. I did contemplate wiring from the batteries to the board, and putting in some nimh batteries. However the amount of stuffing around doesn't seem to warrant it.
