Latest Reviews and Articles
Will your next bike be Intelligent? ABS and Smart Bike Tech
Vitus Vitesse EVO Disc Review – Speed Machine indeed!
Adding weight
Adding weight
Postby heliage » Thu May 07, 2009 8:45 pm
Alot of people are constantly trying to make the bike lighter to make a difference up a hill.
This is probably a stupid question, but, wouldn't adding weight to a bike, to say, go up a hill, and try to do it at the same speed as you go up it without the extra weight make you increase your power output overtime with training. Which if you then take weight off later for the same hill, your average power to keep the same speed would become smaller because of the reduced weight, thus making the hill that much easier to go up? (I'm new to this but I think I've got it right, the power to weight ratio would change significantly)
So big question I have is, would training with added weight do anything? or would it just be a waste of time? (not talking about adding a fwe hundred grams, but at least 10 kilos, or more to the weight.) I guess the other question would be, where would be the best place to put the extra 10 kilos? I was thinking under the seat post cause that'd probably be as if I just weighed more hence not changing too much to the steering.
Repeat the hill to hurt less.
Re: Adding weight
Postby Ant. » Thu May 07, 2009 10:44 pm
heliage wrote:Alot of people are constantly trying to make the bike lighter to make a difference up a hill.
You could add weight and it'd make the inclines harder, but how about just pedal harder up the hills
Cervélo R3
Cervélo P3C
BT Blade
Cervélo P3C
BT Blade
- Alex Simmons/RST
- sogood
Re: Adding weight
Postby sogood » Fri May 08, 2009 7:04 am
Think of it this way. Weight is just another part of the combined resistance you are fighting against, along with speed when going up hills. More weight or speed equals greater resistance. So when going up hills at any given power, a heavier bike-rider combination will just have a slower speed. And if you want to put more resistance in the equation, then push to a faster speed.
Re: Adding weight
Postby ruscook » Fri May 08, 2009 8:45 am
... or use a higher gear and try and keep the same cadence as a lower gear. The higher gearing will give more resistance.
I understand Heliage's point though, it's similar to some who train with a heavier bike with the same gear ratio's so they are "automatically" faster when on their race bike because they're carrying less weight when racing.
Russ
Russ
GT Avalanche 1.0 | TCR Alliance 0 | Giant Bowery | BMW K1300R
Two wheels good, Four wheels bad
Re: Adding weight
Postby othy » Fri May 08, 2009 10:46 am
ruscook wrote:... or use a higher gear and try and keep the same cadence as a lower gear. The higher gearing will give more resistance.
Russ
I ride all week with a backpack, but come the weekend race and bunch rides I definitely feel faster without it. I think it is a combination of the wind resistance, weight and extra comfort.
I don't want to be giving away all my secret training tips though. Sogood is watching.
- toolonglegs
Re: Adding weight
Postby toolonglegs » Fri May 08, 2009 4:15 pm
othy wrote:ruscook wrote:... or use a higher gear and try and keep the same cadence as a lower gear. The higher gearing will give more resistance.
Russ
If you didn't feel faster without there would be a problem.You are going faster without it...but only because your power to weight / aerodynamics has improved...you are still putting out the same watts.
- Alex Simmons/RST
Re: Adding weight
Postby Alex Simmons/RST » Fri May 08, 2009 5:16 pm
Which means, ride faster.
ruscook wrote:I understand Heliage's point though, it's similar to some who train with a heavier bike with the same gear ratio's so they are "automatically" faster when on their race bike because they're carrying less weight when racing.
from a trainer POV, the only time it makes sense to add something to slow you down is if:
- you don't have a hill long enough for your hill repeats and you want to artificially lengthen it (in a time sense)
- you are riding with a slow partner but want to get a good workout
Otherwise, simply ride harder.
But adding a few kg to a bike won't make that big a difference to time up a climb. You'd need to ride with a trailer to really make a decent difference to climbing speed. Then you'll need appropriate gearing.
- Cyclocross
- Cycling Brands
- Azzurri
- Bianchi
- BMC
- Campagnolo
- Cannondale
- Cervélo
- Colnago
- Focus
- Fuji
- Garmin
- Giant
- Malvern Star
- Merida
- Scott
- Shimano
- Specialized
- SRAM
- Surly
- Trek
- Custom Builders
- Generic Carbon
- Delete all board cookies
The largest cycling discussion forum in Australia for all things bike; from new riders to seasoned bike nuts, the Australian Cycling Forums are a welcoming community where you can ask questions and talk about the type of bikes and cycling topics you like.
Brought to you by Bicycles Network Australia | © 1999 - 2018 | Powered by phpBB ®
