Cycle Training
madiganmichael
Cycle Training
Postby madiganmichael » Tue Dec 15, 2009 1:40 pm
Hi All,
Okay this may sound weird but what types of techniques are there for pedaling effectively. I know it may look like my legs are just going around and around but what should I be focusing on to get the best and sustained effort from my pedaling?
silkishuge
Re: Cycle Training
Postby silkishuge » Tue Dec 15, 2009 3:04 pm
Use a trainer if you want to improve pedeling style. 1.5 hs before work and 1.5 hrs after work for 3 months did wonders for me. It is extremely boring though so be inventive in your traning program.
J
Jon's bikes.......
Kona Jake the Snake
Cervelo R3
Cervelo R5
Alex Simmons/RST
Re: Cycle Training
Postby Alex Simmons/RST » Tue Dec 15, 2009 9:11 pm
1. Make sure your bike is well fitted to you.
2. Focus on effort level.
3. Choose a gear that feels good.
4. Ride lots.
JV911
Re: Cycle Training
Postby JV911 » Wed Dec 16, 2009 8:37 am
madiganmichael wrote:Hi All,
you're overthinking...just ride
Alex Simmons/RST wrote:1. Make sure your bike is well fitted to you.
4. Ride lots.
^^^ listen to yoda :D
<---LACC--->
<---BMC SLR01--->
madiganmichael
Re: Cycle Training
Postby madiganmichael » Wed Dec 16, 2009 3:38 pm
Thanks All for your comments so far. I guess what I'm hearing so far is practice makes perfect. So I shouldn't think about where my power comes from or pushing from the toes but just ride. Thanks again and if there is anymore advise out there I for one would greatly appreciate it.
Romper
Re: Cycle Training
Postby Romper » Fri Dec 18, 2009 5:10 pm
I have incorrect technique (a bit toey) so I got told to hop on the trainer twice a week and use 1 leg at a time, and to try and get a continuous, even whir/noise for the trainer if you get what i mean. when you get a consistent noise it means that your using the whole pedal stroke or something.
I'm sure someone else could explain it better
Romper! now stiff yet vertically compliant
Alex Simmons/RST
Re: Cycle Training
Postby Alex Simmons/RST » Fri Dec 18, 2009 6:24 pm
Romper wrote:I have incorrect technique (a bit toey) so I got told to hop on the trainer twice a week and use 1 leg at a time, and to try and get a continuous, even whir/noise for the trainer if you get what i mean. when you get a consistent noise it means that your using the whole pedal stroke or something.
Why is being "a bit toey" incorrect technique?
One legged pedalling will address one legged pedalling technique but the motor recruitment patterns required for that task are different to that required for two legged pedalling. The motor recruitment patterns change as soon as you go back to using two legs. If doing one legged work, then at least one should inertially load the opposite non-drive pedal/crank in order to as closely approximate the motor patterns used in two legged pedalling. But really, why bother unless you don't have use of both legs (temporarily or permanently) or are training to ride one legged?
Here's a tip: use as many legs as you have avaialble, all of the time.
Chuck
Re: Cycle Training
Postby Chuck » Fri Dec 18, 2009 6:38 pm
Alex Simmons/RST wrote:Here's a tip: use as many legs as you have avaialble, all of the time.
:lol: :lol:
You'd think the message was starting to get through by now :?
FPR Ragamuffin
Romper
Re: Cycle Training
Postby Romper » Sat Dec 19, 2009 2:07 pm
Scratch what i said, Alex probably knows more then the guys at my lbs.
LISTEN TO HIM
