Indoor Trainer
• Page 1 of 1
Indoor TrainerWith all this rain (Sunshine Coast Qld) I splashed out for a magnetic indoor trainer, what a workout, new to the scene so I only spent an hour, did,nt think I could sweat that much
Re: Indoor Trainer
You shouldn't sweat too much,you are over heating...go and buy some f'ing big fans from bunnings...these days I am cold on the trainer when I get on and have to strip down once I warm up!.You will get a better work out when you don't over heat and will be able go longer.
Re: Indoor TrainerInteresting, I did think about a fan but thought it might introduce a chill factor (damp & humid), how long do you spend on a trainer
Re: Indoor Trainer45 minute to 75 minutes is my normal.Up to 2.5 hours if I am feeling insane!...and the movie is good
Re: Indoor Trainer
For every watt of power generated at the cranks, your body is generating another 4 watts of waste heat, which it needs to dissipate. If you are doing, for instance, interval efforts at 300W, then your body is effectively a 1200W heater. Without a substantial cooling aid when training on a stationary unit, you will overheat, and with that comes a sizeable loss of performance, reduced gross metabolic efficiency and a significantly sub-optimal training session.
Re: Indoor Trainer
+1 on the BFF
Re: Indoor TrainerOn the topic of indoor trainer, what's the tyre pressure to put them on (MTB with slicks)? I've tried running them at full road pressure and it seems to be lose traction no matter how tight I put them but when I put no tyre pressure on them, they seem to run fine with no slippage. Do I continue to run them on no air pressure?
Re: Indoor Trainer
really? my experience is exactly the opposite i.e. keep the pressure up and the roller hard against the tyre otherwise i'll break traction and there will be bits of rubber everwhere...just like doing a burnout!
Re: Indoor TrainerI am with JV911, I run my trainer tyre ( Vittoria Zaffiro Pro Home Trainer Tire 700x23) at 145psi the pressure recommended by Vittoria and Tacx (my trainer manufacturer ).
Running too low around 100psi, causes problems of slippage. my blog Nick Cowie, member of Peel District Cycling Club
• Page 1 of 1
