Indoor Trainer
Posted: Wed Apr 21, 2010 9:25 am
With all this rain (Sunshine Coast Qld) I splashed out for a magnetic indoor trainer, what a workout, new to the scene so I only spent an hour, did,nt think I could sweat that much
BNA - For the Australian Cycling Community
http://www.bicycles.net.au/forums/
You shouldn't sweat too much,you are over heating...go and buy some f'ing big fans from bunnings...these days I am cold on the trainer when I get on and have to strip down once I warm up!.You will get a better work out when you don't over heat and will be able go longer.Mustang wrote:did,nt think I could sweat that much
For every watt of power generated at the cranks, your body is generating another 4 watts of waste heat, which it needs to dissipate. If you are doing, for instance, interval efforts at 300W, then your body is effectively a 1200W heater. Without a substantial cooling aid when training on a stationary unit, you will overheat, and with that comes a sizeable loss of performance, reduced gross metabolic efficiency and a significantly sub-optimal training session.Mustang wrote:With all this rain (Sunshine Coast Qld) I splashed out for a magnetic indoor trainer, what a workout, new to the scene so I only spent an hour, did,nt think I could sweat that much
+1 on the BFFtoolonglegs wrote:go and buy some f'ing big fans from bunnings...
really? my experience is exactly the opposite i.e. keep the pressure up and the roller hard against the tyre otherwise i'll break traction and there will be bits of rubber everwhere...just like doing a burnout!SmellyTofu wrote:On the topic of indoor trainer, what's the tyre pressure to put them on (MTB with slicks)? I've tried running them at full road pressure and it seems to be lose traction no matter how tight I put them but when I put no tyre pressure on them, they seem to run fine with no slippage. Do I continue to run them on no air pressure?
