by mickpc » Mon May 10, 2010 7:38 pm
I have just received a heart rate monitor (lucky me eh) and this has prompted a few questions...
One of the main things that has become apparent is that warming up properly means that you can get the most out of your ride. So what are the optimal figures for warming up, in BPM terms if anyone knows...
Also I am wondering about general info on using the heart rate monitors, if people could help me out with a few links, that would be great.
I think that's all for now, thanks
Mick
mickpc
by Forum Ads » Mon May 10, 2010 7:50 pm
by Mustang » Mon May 10, 2010 7:50 pm
Which brand, model, did you buy?
Mustang
by mickpc » Mon May 10, 2010 9:02 pm
Polar cs200.
Mick
mickpc
by Toolish » Tue May 11, 2010 7:42 am
Can open up a whole can of worms.
Heart rates are a very personal thing. What is right for you is unlikely to be right for someone else. The first step is to do some testing and then establish some goals.
I use Joe Freils zones for my training which are based on Lactate Threshold tests...the test is bloody hard work but is worth it for the result.
Also a max heart rate test may be handy.
Toolish
by twizzle » Fri May 14, 2010 10:11 pm
Warmup - up to 15 mins at less than 60% of HR range (ie. 60% of the way up between resting HR and Max HR, which can be estimated or measured). I'm slack, I tend to get bored after 5 minutes and hammer. Probably explains why I have so many bouts of knee problems.
I ride, therefore I am. ...real cyclists don't have squeaky chains...
twizzle
by tripstobaltimore » Mon May 17, 2010 6:22 pm
optimal figures for warming up? Just get out there and ride for 20 minutes. It doesn't need to be complicated.
tripstobaltimore
by toolonglegs » Mon May 17, 2010 6:26 pm
The only complicated thing is keeping your CS200 dry in the rain  .
by twizzle » Mon May 17, 2010 7:32 pm
toolonglegs wrote:The only complicated thing is keeping your CS200 dry in the rain  .
Yes, guy at work has just discovered that. He's not a happy camper.
twizzle
by Dunk » Wed May 19, 2010 2:57 pm
I had the same problem myself - I used to wrap it in glad wrap if it looked like a wet ride. I never had any problems with water after that.
Dunk
by Colin_T » Wed May 19, 2010 10:32 pm
twizzle wrote: Warmup - up to 15 mins at less than 60% of HR range (ie. 60% of the way up between resting HR and Max HR, which can be estimated or measured).
That pretty well covers it. Ride slowly & comfrotably for the first 15 minutes, then increase the pace if you want to. The same applies when finishing a long ride. Slow down for the last 10-15minutes. Stretching before and after a ride is recommended but I can't be bothered doing that. I prefer to do it while rolling along. twizzle wrote: I'm slack, I tend to get bored after 5 minutes and hammer. Probably explains why I have so many bouts of knee problems.
LOL to the boredom bit
Kicked a black cat? Sounds more like ran over one, backed over it, hunted down its mother and did the same.
Colin_T
Return to Training
