Fixed gear training
• Page 1 of 1
Fixed gear trainingIs there any set standard or approximate for fixed training,I have been told it pays dividends for road racing?,,"eg: 120 rpm (AT) 30kph" I would like to dial a gear and train in it for the duration of the ride,,
When everything's coming your way, you're in the wrong lane.
Bike 2011 Scott ,,all good Genius 27 sp flat bar ,modified with aerobars etc a strange beast but love it ,,kicks ass
Re: Fixed gear trainingFor 700c the gear would be 52.5 inches (old school) or 4.167 metre rollout. (i.e. 120 rpm (AT) 30kph)
Depending on your cog or CW that will get you there, get a gear-chart. Lone Rider- I rode on the long, dark road... before I danced under the lights.
Re: Fixed gear trainingThere's no standard. The "standard" depends on the rider, the type and phase of training, and the type of terrain.
Re: Fixed gear trainingThe 80 km ride varies so much nothing super steep,,Might dial a random gear and go with it ?,,experiment might be the answer,,
Re: Fixed gear trainingIf you check a gear chart you will see, there is a standard.
39x20 will get you there (or 47x24), 30Kph at 120 rpm. Simple as that. Lone Rider- I rode on the long, dark road... before I danced under the lights.
Re: Fixed gear trainingThere is an equation to express gearing, but there's no standard as to which gearing to use for an individual's training. What fixed wheel training gives is approx 20-30% extra work (subject to terrain and other parameters) and variable cadence (spin). You can ride harder on multi-geared bike and achieve the same level of work.
Personally I used 46x20 so that's 62inches, and that worked for my fixed training, as a preparation for road (and track)... hope it works for you, puffdaddy. Lone Rider- I rode on the long, dark road... before I danced under the lights.
Re: Fixed gear trainingSorry if I am thick or missed it ,,What does that equate in cadence and kph ?
Re: Fixed gear trainingThere's 2 schools of thought, old school and new school
Old school is what brenteno has quoted. Really low gear 52.5" I think he quoted (too lazy to scroll down) New school is what I do. 81" and smash the [something] out of it. I've hit 70kph on it Both Old school and New school have their benefits. I'll give you 2 options; 1. Ride whatever comes with it and if you hate it change it 2. Train on different gears, changing it every so often I've got stuff on ebay
Re: Fixed gear trainingOk may try 30 kph @100 rpm or so ,,Normally sit 38-42 kph on the flats so going to be interesting
K.I.S.S. think "Fixed gear training" means fixie. FYI. Lone Rider- I rode on the long, dark road... before I danced under the lights.
Re: Fixed gear trainingUse this gear calculator to work out your gearing and rpm.
http://software.bareknucklebrigade.com/ ... pplet.html
• Page 1 of 1
