do any of you 'bodybuild'?
Postby ftssjk » Tue Oct 04, 2011 9:52 pm
not in a 'competitive' mr universe arnold schwarzenegger way, but in a decent effort sort of way.
I know it doesn't really give you much power, but I had an idea of first body building as the 'main goal', then using cycling as cardio, (i can't really swim, and i'm not very good at jogging). Then after a while to 'cut' i'd just be cycling heaps.
thoughts?
My ideal physique would be around 80kg with a body fat % of around 8%.
at the moment i'm 70kg. Not sure how much body fat i am, but i will buy some calipers one day lol.
Re: do any of you 'bodybuild'?
Postby vander » Tue Oct 04, 2011 10:17 pm
When I was bulking I did almost no cardio. When I was cutting I did a tiny bit of HIIT about 20-30min 3-5 times a week. Cardio is really not necessary with bodybuilding and can have a deleterious effect. So cycling and bodybuilding don't really go together too well. Saying that I am just getting back into lifting weights regularly again after a good 8-10weeks off.
Bodybuilding takes a lot of time and effort. bodybuilding.com is your bible but you need to be careful and not follow everything you read. Saying that I love lifting gives you a great feeling. Being strong is good.
- trailgumby
Postby trailgumby » Tue Oct 04, 2011 10:44 pm
Shoulder is almost 100% again. w00t!
Lower back is still an issue, but the core strenght stuff has done wonders for my bike handling and confidence tackling tricky stuff off road. The bike just seemed to flow around Manly Dam last time I rode there coupla weeks ago in a way I didn't think was possible, and I bested my previous PB by over a minute without really going out with a plan to ride at training pace.
It seemed like a continuous zen moment
... until some twerp rang me on my mobile.
- trailgumby
Postby trailgumby » Tue Oct 04, 2011 10:46 pm
- skull
Postby skull » Wed Oct 05, 2011 9:03 am
However I do complete a body weight strength circuit to maintain and also because I am in the Military and need to maintain some upper body strength. I complete a chin up, push up, sit up pyramid. 10 of each then 9, then 8, all the way down to 1.
It goes alright.
Postby biftek » Wed Oct 05, 2011 10:28 am
plus i feel a lot more healthier and fitter
bulking up doesn't happen over night it takes a lot of training and a good diet as well genetics to pull it off
Postby Anakist » Thu Oct 06, 2011 10:01 pm
*Warning: massive generalisation ahead*
Cycling is an endurance activity, which relies on the nervous system and muscles being more efficient at what they do. So the same strength with less mass and size.
Bodybuilding is low weight, high rep to failure and one day per week per muscle group kind of stuff, and the aim is to fill the muscles with fluid to make them look big (sarcoplasmic hypertrophy). This makes large muscles with relatively low strength and is IMHO a waste of time.
You could a little powerlifting stuff (myofibrillar hypertrophy) which trains nervous system recruitment and builds more muscle fibres (myofibrils) by doing low rep, high weight stuff, and you will get strong without the size issues, but the best thing to do would be largely bodyweight exercises (like Crossfit, Convict Conditioning, Pavel's Naked Warrior stuff, gymnastics), and cycling. The more time you spend cycling, the more efficient the pathways become, and the better at it you become. Bodyweight exercises are pretty damn good at getting you strong, without getting you big. You will still grow more muscle fibres and get bigger, but not to a bodybuilder extent.
James
2010 Merida Cyclo Cross 4 Disc
2006 Avanti Escape with slicks and "Upgraditis"
2008 Buell 1125r
Postby vander » Thu Oct 06, 2011 10:10 pm
Increasing strength will cause an increase in size and also (more importantly for cycling) heavier. Bodyweight stuff can still make you pretty big.Anakist wrote:Two totally different aims. If you want to weight train as a tool for cycling, don't go for a bodybuilding style workout.
James
Dont know how to do a picture so ill just give you the link - http://www.google.com.au/imgres?q=male+ ... 9,r:16,s:0
Saying that I still do it and its good to do. Unless your a professional does it really matter? Lose the bodyfat not the muscle
Postby ATP » Thu Oct 06, 2011 10:18 pm
Spent some time during a lazy summer learning about nutrition and basic compound lifts/exercises. I chose my goal to gain some weight to become more "functional". Within 18 months I was up to 75kg and fairly lean (~13% BF) and my goal was met. That was a couple of years ago, and after some "minor" life obstacles resulting in me losing a bunch of weight, I'm back to around that 75kg area.
I'm actually about ready to start another bit of a bulk up, just waiting for a few more dollars into the account to buy some weights for home. I'm going to move up to the 80+kg class and see how it is!
Postby Anakist » Thu Oct 06, 2011 10:21 pm
Hence thevander wrote:Increasing strength will cause an increase in size and also (more importantly for cycling) heavier. Bodyweight stuff can still make you pretty big
http://www.google.com.au/imgres?imgurl= ... wAg&dur=77Anakist wrote: You will still grow more muscle fibres and get bigger, but not to a bodybuilder extent
James
2008 Buell 1125r
Postby Fresh » Fri Oct 07, 2011 12:20 am
Postby Crawf » Fri Oct 07, 2011 2:28 pm
Lift something from the floor(deads, cleans etc), press something overhead(military, push press, jerks etc) and do a deep knee bend (squats, lunges)... all on your feet.
In it's most simple form this approach will work just about every muscle in your body in the same session, and flog your lungs if you are lifting enough.
- ColinOldnCranky
Postby ColinOldnCranky » Fri Oct 07, 2011 3:16 pm
So, my advice, for what it is worth - aimed at working out at moderate levels as a lifetime thing
If you are a few years or more past puberty and you are seventy kg, then it is likely that is about the right weight for you. If you are now seeking to add ten kg then you should also question yourself on the likely long term benefit as it could be less positive and more negative. You can get lots of power without much increase in weight.
If you are gonna build up above your current and stable weight be wary. There is some danger in maintaining it for life. For example, I have never done massive powerbuilding and body building levels, just what is needed to enable me tio launch the boat without fear, do some bricklaying and other stuff, support me in basketball, etc. Yet in the last decade I have torn both longhead bicep tendoms from bone. Ditto for my rh supraspinatus tendon (three times), my infraspinatus t(wice) and my subscapularus coming close (twice). I am currently recovering from my third stint of significant shoulder work. There are a number of reasons and many things I could have done better but will you do better? Thinking you will and actually doing so are not the same.
Don't get me wrong, there are substantial benefits in being a little more powerful and comfortable when doing fairly heavy activities. I am certainly still more functional than most of my peers and a lot of that is due to comfortable extra power. But the risk is there so, as I said, be wary.
But as an inspiration, a demionstrationthat it does not need to be so, look no further thanTom Hafey. Following are current at age 80, and afaik he has not needed to attend surgery any more than anyone else of his age. It can be done.
- Do not expect a lot of help from gym membership in terms of protecting you from damage by watching out for you or even with adequate advice and knowledge. The business model does not allow for it.
- A great source of info and understanding is at http://www.exrx.net/Exercise.html
- The best source of freeweights are hock shops as they charge by the kg and will be half the price of new.Besides, fresh new weights just look like someone has hit mid-life crisis, used weigths give the appearance that you are in it for the long run. In due course you need a lot of freeweight even without bodybuidling in order to have several different items set up in advance. I have 300kg of weight plates (excluding grips, bars, collars, etc) including machine-weights and I have never worked at bodybuilding or power lifting and have never been bulked-up or buff.
- Those gee-whiz breakthru wonder-machines on TV shopping channels are mostly crap.
- Rowing machines are one of the great things to have in your shed - especially the hydraulic ones for reasons of space. (I wish I had never given mine away )
- Make your own superior really l-o-n-g exercise bands out of shock-chord (from BCF, Bunnings charge about three times the price) - My own designe are simple, great for taking with you on trips, light, easy to attach to structures. PM me and I will send some detail and pics.
- In my experience, those comical/extreme looking ultra-body-builder junkies are a great source of help and knowledge at a level of detail you will not find elsewhere and without judging you adeversely. They do not try and induct you into their way of life and competition if yo do not want it - just knowledgeable and helpfull and safe.
- notwal
Postby notwal » Sun Oct 30, 2011 9:47 pm
There are good reasons for anyone but particularly older guys to do some weights resistance training.
1) It maintains an appropriate level of strength
2) It keeps your bones hard
3) It keep your testosterone levels up
The last one is often overlooked. Keeping your hormone levels up directly affects your sense of well being. It's good for your energy and concentration not to mention your libido. It's also good for recovery.
I'm an older bloke and for many years I used to maintain a modest weights program. I hit every muscle group once a week but I wasn't into supplements (except for a bit of protein) or a precision diet.
When I got back on the bike 13 months ago I stopped the weights only because I rode every day and didn't feel like lifting after riding.
I lost a lot of weight in about six months and then stabilised. Then I started to notice the strength loss. For me that manifests as shoulder niggles as well as a loss of facility in everyday heaving stuff about. Now I am back at the gym once or twice a week and I'm feeling better for it. I don't expect to put on more than 3 or 4 kilos with the work that I'm doing, even so I'm ambivalent about putting on ANY weight that makes me slower up hills. I'll see how I go.
The other thing I have to do is get back into yoga. I recommend it. Flexibility is the third leg of fitness.
Postby dynamictiger » Sun Nov 06, 2011 10:57 am
I am not built like most of you fellows think more like the Hulk (by the way, before you start telling me I can loose more weight etc, I would point out I can lift most 4 cylinder motors straight out of a car). Got up to 130 ish kilograms, went on a diet, started an exercise program and in 12 weeks weighed in at 115kg. Went on holidays gained a kilo or so, and am now nearly back to what I was a few weeks ago. I find Swimming is developing my triceps, shoulders, chest and back. Kicking is strengthening my core muscles and then to really give everything a kick along I go to a few classes at the local gym.
HTH
Users browsing this forum: piledhigher2
